Trying to find manel ob7
Http://www.mobilityscootermanuals.co.uk/index.php?route=product/search&search=Rascal&category_id=68
You can get the manual here
Contact Electric Mobility:-
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
SOURCE: Need service manual or electrical wiring diagram.
one ofthe best ways to work it out is the find the motor controller, normally it's a black box located under the seat,
Now remember you have two wires from the batteries B+, B-, two wires to the motor, M+, M- and some smaller wires on maybe a ten connector block that leads to the tiller where the throttle on the handlebars is located.
Hope that helps
Regards
GeWiz.
SOURCE: Rascal 240 scooter Battery charged ,scooter
Hello
There is an overload protection switch in it. It will look like the the protection switch that can be seen under the mixes. The picture of the overload protector is added here. Its press button will only seen outside. Just putsh it once and check. The motor has carbon brushes inside it to get armeture contact. If these burshes are worn out, the motor won't turn, and the scooter won't move. There will be two of them in opposite directions. They are replacable parts. The picture of it is also given here. Check these first. If you need anymore assistance from me, feel free to get me by FixYa.
OK
SOURCE: 2001 rascal electric wheelchair booklet
http://www.scootaround.com/resources/manuals.htm
If you scroll down to Electric Mobility you will find the links to 14 different Rascal Electric chairs as they are listed by product number im afraid i couldnt pin it down any more then that
Ahoy!
A free PDF user manual for the Rascal 388 Deluxe can be downloaded from:
http://www.mobilityscootersplus.com/down...
Also, there's a free specifications and description PDF brochure at:
http://www.electricmobility.co.uk/userfi...
If there's anything else, you can find it online by doing a simple search on Google, though for technical information, there's likely to be a video of it on YouTube if nobody has thought of looking there, otherwise, you can pick up the phone and call a retailer as I'm sure they'll be willing to advise.
Pirate!
