Question about Garden
My lawnmower is only 10 months old and has developed a bad oil leak from the engine main shaft oil seal, they say that oil seals are only guaranteed for 90 days, I said that the mower has not been used for a total of 90 days. I thought the seal should last longer don't you ?
  • 143 Answers
Could you have hit something very hard with the blade while cutting? This could cause the shaft to bend and damage the seal. I have never heard of a 90 day guarantee, seals normally last for years.
Posted on Jul 03, 2009
Why would I have oil in where my flywheel is and
Give more information. What car, what year model? If there is oil where the flywheel is, chances are you have a leaking rear main bearing oil seal or leaking gear box primary shaft oil seal. Coil packs? They should be there to make the car go.
Sep 27, 2014 | Cars & Trucks
Oil is leaking, how can I tell if engine main
You don't give make or model. Here goes , The engine has a rear maim seal behind the fly wheel if it leaks the leak will be from the clutch housing. It has a front seal behind the crank shaft timing cover.it can leak from there . it can leak from the oil filter and oil pressure switch . Can also leak from the top timing cover gasket and cam shaft seals.
Sep 21, 2014 | Cars & Trucks
Briggs & stratton 18hp model 422777
check around the sump breather pipe. When you replace the bottom seal it is advisable to inspect the shaft as if there is a groove there the new seal will not work as intended.
Jun 23, 2013 | Garden
Oil leak on driveway coming from front of engine
Dear Sir,
Here is the oil leaking Problem Identifying Technique
Engine oil leaks from the valve cover gasket are common.
  • The intake manifold plenum gasket may leak and cause increased oil consumption/burning and a spark knock during acceleration; the gasket should be replaced.
  • External oil leaks from valve cover gaskets, intake gaskets (front or rear), and the rear crankshaft (rear main) seal area are common. The rear main seal is an unlikely source. Normally, the bearing cap mating surfaces (as well as the sealing surface between the oil pan and bearing cap) are the source for the leaks.
  • Engine oil leaks at the distributor can be misdiagnosed as leaks from theintake manifold seal, oil pan gasket, or rear crankshaft (rear main) seal. A revised distributor is available if oil is found inside the distributor.
  • If the oil filter casing shows signs of distortion from excessive oil pressure, theoil pump should be replaced.
  • Often misdiagnosed as a leaking oil filter gasket, the oil filter adapter can seep from between the adapter and engine block.
  • Carbon buildup on the top of the piston is common. As the buildup increases with mileage and over time, symptoms may vary from light ticking, to ticking/hammering, to hammering/knocking noises. Fuel injector cleaner often solves the problem.
  • I think it helps to analyse u r Problem
    Nov 02, 2012 | Toyota Cars & Trucks
    I have a Toro "personal pace" 6.75hp lawnmower, approximatly 6 yrs old. Oil is leaking from the bottom of the engine block. Can a Harry Homeowner fix something like this. thanks ,Dennis
    Sounds like a crankshaft seal (if it's the very bottom). Leaks also develop around the bottom of the oil fill tube and sometimes the oil breather. A happy homeowner would be well advised to take this thing apart, clean the carbon off the piston, valves and head. Buy an engine gasket kit and install the new seal (it comes in most kits). It is not too hard
    Or...you can just take the economical approach and just get the seal and replace that only. After 6 years though, cleaning the carbon off the top-end is well advised.
    Aug 28, 2010 | Toro Garden
    Oil leak under front sproket
    The oil seal on the sprocket shaft has probably gone bad. Remove the sprocket then clean the shaft to aid in removing the old seal. A screw driver and small hammer is used to pry the outer edge of the seal inward. Realize that you will butcher the old seal in the process of removal. The only other way to remove the old seal is to pull the engine and split the center case.
    Jan 18, 2010 | 2001 Yamaha YZ 426 F
    Rear main seal leak
    If somebody told you that you have a main seal leak what they meant was the round seal that is around the circumference of the output shaft of the crank. This same output shaft is basically hooked up to the transmission, or through to the transimission through a clutch. Well after some time, the round seal, it looks something like a flat donut, leaks. Imagine stretching a small spring around a shaft of steel and wrapping the spring in rubber. It will stop the oil from leaking along the shaft and out of the engine. After wear and tear, it needs to be replaced.
    If this is the case, well, given that you have not said what type of vehicle you have, you would need to either pull the engine out or drop or pull out the transmission to get at the shaft and replace the $10 seal part. A lot of work for a small item but it will continue to leak until of course you run out of oil and ruin the motor.
    I hope this helps somewhat.
    Sep 21, 2009 | 1989 Chevrolet K1500
    Oil leak tecumseh engine OVRM120-22053F
    oil seal is worn out from durbis wrapped around crankshaft need to replace oil seal by removing blade and hub
    clean cranksaft with fine sand paper
    a sharp awl punch in the outter edge corner of seal on a 45 degee angle then slide seal off
    heres the manual.pdf page 75
    Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
    1994 saturn sl2 automatic,with really bad oil leak.
    There are only two paths for oil there. The rear main, and a oil galley plug a little higher up, about 2 o'clock.
    Nov 12, 2008 | 1992 Saturn SL2
    Rear main seal leak in F163 engine
    Don't know if there is an updated seal available but if the machine is eating seals that fast you need to carefully check the flex plate that couples the PTO shaft of the engine to the rotor shaft of the generator. If it is bent, cracked, or out of balance you'll eat seals due to vibrating the back end of the crankshaft around.
    Carl
    Oct 08, 2008 | Welding Tools
    Garden Logo
    258 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
