Question about Refrigerators
Bottom of freezer filled leaked water, froze and ran over onto floor. The grate at the bottom, back inside of the freezer was frozen over. I banged the ice off that and the bottom of the freezer under the bottom basket. What else should I do?
  • 89 Answers
You need to clean the drain if tis is a side by side you usually see the drain hole at the bottom at the back of the freezer
Posted on Jul 03, 2009
Ice forming on bottom of freezer with water leaking out from under
I'm guessing the drain from the freezer defrost pan (below the freezer coil) is clogged and overflowing into the bottom of the box. You'll have to turn off an defrost the freezer, then remove the sheet metal on the back to expose the coil. Try pouring some water into the drain pan and if it backs up, use a fine wire like a sewer snake to clean it out.
Feb 28, 2018 | Maytag MBF2256H Bottom Freezer...
My Bottom pull out freezer is leaking water onto the floor from on top of both feet of the unit. The freezer also has frozen water in the bottom of the unit. I have removed the frozen water in hopes that...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 15, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
Hi, have have 21' Bottom Freezer refrigerator, model 69142992. My bottom freezer is getting a sheet of ice on the bottom, where the basket becomes frozen in place. The the freezer leaks water onto the...
hi dear you have to unplug ur ridge and then open the freezer door remove the food try to defrost the ice by a hair dryer then remove the basket boil some water and pour it on the white metal back inside the freezer tell you feel the water goes inside ,your problem is drain blockage ,or stop the fridge for 24hours and it will work normally
Sep 11, 2010 | Kenmore Refrigerators
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
Ice in the freezer side bottom of my side by side Maytag.
You are having either a defrost problem combined with the defrost drain being frozen over. Need to unplug and remove the rear panel in back of freezer to examine exactly what is happening. Some models like yours have electronic vents that cole if the control becomes defective. . The other possibilities ar the
Adaptive Defrost part number 61005988
The defrost heater with defrost thermostat part number 61006199
Visit our site or click on your model number or part number. I will be here to assist you in your repair, Thanks Sea Breeze
Click Here=> PART NUMBER AND MODEL SEARCH FEATURE
Aug 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Freezer, water problem
you have a frozen defrost drain, first of all defrost all of the ice out of the drain pan behind the grate, once the ice is gone you'll see a drain hole that goes thru the floor of the refrig. you need to flush some hot water thru this drain.
I use a big syringe filled with hot water to do this it will force any sludge build up out of the drain tube into the drain pan.
kind of an easy fix even if you aint 10=)
Dec 20, 2007 | Refrigerators
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
