Question about Electronics - Others
My generator runs but will only put out 3.8 volts on the 120 volt receptacle. Changed AVR on the advice of Champion Technician. Problem persists. What else can I check?
  • Craig Butler
    Craig Butler May 11, 2010
    Can you use a meter? I can help you with a meter.
  • 3 Answers
I'm not sure what
AVR = (automatic voltage regulator?)
You could try to excite the generator pg.7
http://www.powermate.com/generators/0062929_0706.pdf
Check the brushes pg. 7
Check the capacitor
http://wiki.answers.com/Q/How_do_you_test_a_capacitor_using_a_multimeter
Other than that you could open the box where the outlet is sometimes the wire breaks off or comes loose even if its new. Good Luck
Posted on Jul 17, 2009
Voltage has gone to ceiling
the generator is spiking the 120 volt plug to commercial voltage bad regulator on the unit more then likely or wired improper
Nov 20, 2015 | Coleman Pm0545003 5000 Watt 10 Hp...
Miller trailblazer 302 it has 110 volts but no 220 volts
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
Feb 19, 2015 | Miller Trailblazer 302 Welder Generator...
It may well be the AVR, how can I test this? Thank you so much.
Disconnect the avr and unplug the wires going to the brushes then put 12 volts to the brushes and see if the generator puts out 120 volts.
Apr 10, 2014 | Electrical Supplies
My portable generator runs great but only produces 7 volts and 20 volts on each 110 volt receptacle and 20 volts on the 220 volt receptacle. any ideas on troubleshooting steps to find the problem part?
Assuming the speed is correct check the voltage on the rotor brushes during running (Caution) It should be DC. If you have low or no DC voltage then the capacitor in the end of the generator housing is bad, or the AVR. If you do have voltage then make sure the slip rings are clean and shiny, from there you may have a rotor or stator issue that needs carefull resisitance check
Oct 13, 2013 | Buffalo Tools Sportsman GEN7000LP Portable...
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
Low current. Will hardly drive a sander or lights. Voltage guages says 120V. Unit is 3 years old but has maybe 10 hours of use max
I found this at http://www.championpowerequipment.com/tech-bulletins/
AVR Voltage Adjustment
This bulletin covers the following Champion Power Equipment models:
C46535 C41150 C41365
C46540 C41155 C75520E
C49055 C41255 C71350E
Note: Read instructions completely before performing service.
1. On the end of the generator locate the round yellow cover held on by two 7mm bolts.
Remove the two bolts and the yellow cover will come right off.
2. At approximately 7 o'clock you'll see a kidney shaped electrical component called the AVR,
which is held on by two 7mm bolts. Remove the two bolts but do not disconnect the wiring
and turn the AVR over so you can see the backside. You should see a round part coming off
the AVR, this is the capacitor. You should also see a small rectangular box with a jewelers
screw, this is your voltage adjustment screw.
3. With a flat head screw driver turn the jewelers screw counter clockwise and this will lower
the voltage. As the screw is turned back watch the volt meter to see adjustment, the
generator must be running to do this.
4. Adjust the screw until the meter reads 250 volts. On model C46540 when the toggle switch
is turned to the 120 side the volt meter should read around 130 volts. Optimum voltage is
121.8 volts.
5. If voltage does not decrease or does not hold a steady output please contact Champion at
877-338-0999 for a new AVR.
If you have any questions, please contact Champion Power Equipment:
Champion Power Equipment, Inc.
10006 Santa Fe Springs Rd.
Santa Fe Springs, CA 90670
Phone: 1-877-338-0999
Email:
tech@championpowerequipment.com
Jul 02, 2011 | Champion International Champion Power...
I have a PC 6500 watts generator. The 120 volt receptacle is already occupied. I have an appliance120volt/30 amps that has a 10/3 cord and is furnished with a standard 3 pin twist plug. How can I used...
How many amps is the 120/240 volt circuit? I can tell you how to split it into two 120 volt circuits. A twist loc cord end, a piece of four conductor cord, two electric boxes, two receptacles would be needed.
How many amps?
Nov 12, 2017 | Porter Cable 6,500 Watt Contractor...
Coleman powermate 2500 generator : engine runs good ... little to No power on recepticle ... vom reads 2. volts
Sounds like you need to remagnitize your alternator, you can do this yourself but do it like this.
FIRST AND FORMOST STOP THE ENGINE AND WAIT TILL IT MAKES A COMPLETE STOP! AND LOCK OUT THE ENGINE SO IT WILL NOT ACCIDENTALLY START.
 pull the spakplug wire off the engine this WILL HELP ENSURE IT WILL NOT START. next take an old 120v power cord and cut the plug off with atleast 8 inches of wire on it. if it is a 2 prong wire or 3 it doesnt matter. grab your self 2  nine volt alkaline batteries, try just one battery first by plugging in the cord into a 120 volt receptical on your generator and make sure the circuit breaker is in the on position. MAKE DAM SURE THE GENERATOR IS NOT RUNNING BEFORE YOU DO THIS OTHERWISE YOU COULD BE ELECTROCUTED. it is quite safe as long as the generator is NOT RUNNING. put one lead on one terminal of the nine volt and the other lead on the other terminal and you will see a small spark if done right.MAKE SURE YOUR NOT DOWNWIND OF GASOLINE FUMES! if you have a 3 wire cord do not use the green ground lead use only the black and white or blue and brown. if its a two wire cord you cannot get it wrong. tap the wires on the battery terminals a few times. this shoud have remagnitised your rotor and stator. remove the cord from generator completely and put it away from kids and the incredibly stupid for safety. restart generator and plug in an appliance to see if it is making electricity. I recommend using a true rms digital voltmeter to check the voltage it should be between 110 and 130 vac rms for non regulated generator sets. if the 9 vold didnt do it you can use 2 nine volt batteries in series to flash the field. SAFETY FIRST ! ELECTRICITY CAN KILL, YOU DO THIS AT YOUR OWN RISK, I AM NOT LIABLE FOR ANYONES STUPIDIY. IF YOU ARE UNSURE HOW TO DO THIS THEN DO NOT DO IT! TAKE IT TO A QUALIFIED REPAIRMAN. LIFE IS IRREPLACIBLE SPEND A FEW BUCKS TO FIX.
Jan 16, 2009 | Coleman Powermate Proforce 2500 Generator
Coleman Powermate Generator 4600 series
Starts Generating 120 volts and whitin 30 seconds is putting out 0 volts, and the generator has high speed
Feb 19, 2008 | RIM BlackBerry Pearl 8100
Electronics - Others Logo
749 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
