Question about Dryers
I have an older kenmore gas dryer. The problem is that it is not heating up. I can see the element glow but a flame is not produced. I have checked continuity on the thermal fuse and the thermostats and they appear to be good. Where else should I look?
  • 5,911 Answers
If this is an older dryer and you've never had to replace any components on it until now, you may still have a bad igniter. Just because it glows, does not necessarily mean it is good. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
It is common for the igniter to become weak with age. If it does not draw enough current potential, the gas safety valve will not open and you have no ignition.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 03, 2009
My dryer s\tarts and has heat but the heat turns off and does not come on again. The heat (glow) element turns orange after that but the blue flame never comes on after the initial start. Is there a sensor...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 12, 2010 | Kenmore 74212 Gas Dryer
No electric flows to glow element on kenmore gas dryer 8798 0100 79801. there is continuity in glow element and fuse and flame detector.
heatman101
Aug 28, 2010 | Dryers
The dryer is not heating. The Heating element turns on and some times the flame comes off the then shuts. Most of the time the flame won't turn on
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Kenmore 24032\24036 Top Load Washer
Dryer is blowing cold air
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Feb 22, 2010 | Kenmore Dryers
GNSR465EB3WW
Jan 18, 2010 | Kenmore Dryers
Dryer drum is rotating but no heat is present
Oct 23, 2009 | Dryers
FLAME ON SART UP NONE AFTER
Replace the gas valve coils if the ignitor glows but does not light. Replace the flame sensor if the ignitor does not glow.
Aug 29, 2009 | Kenmore 73952 Gas Dryer
Not drying clothes not producing heat
Aug 26, 2009 | Dryers
Kenmore dryer not heating
Check the following-- Gas valve coils Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Jun 05, 2009 | Kenmore Dryers
My dryer does not heat up
You should see a flame if gas, glowing wires if electric(Heating element)
Oct 21, 2008 | Kenmore 63942 Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
