Question about D-Link AirPlus G DWL-G710 Wireless Range Extender
D-Link DWL-G710. I can't login because I've forgot my username
I have connection with my D-Link DWL-G710. He ask for a username and password. Even after I push the 'reset' buttom, I can't login with 'admin'. Probably, I've saved another username and password witch I have forgotten. Can somebody help me how to reset the password or do a full reset?
    Sniper:
  • 53 Answers
When pressing the reset button, you must hold it for about 10 seconds.
Posted on Jul 03, 2009
  • 585 Answers
Requires a "hard reset" which is accomplished by unplugging the power cord from the jack first, then hold in the reset button with a toothpick or other small object. While holding the reset, plug the power back in and continue holding the button for at least 10 seconds or so. It will take the thing a few minutes (mine used to take up to 15, I thought I killed it!) before the thing comes back to life.
Posted on Jul 15, 2009
Forgot my username& password for my market app on
Forgot your username?
If you've forgotten your username, and you're logged in on your device, you can follow these instructions to find it:
1. Click the "gears" icon to go to the Options menu.
2. Tap the "Account Info" section where you see your Textfree number
3. Your Username is the name just before the @textfree.us.
Once you found the username,
Enter username in Login screen and click the link "I forgot my password". So password will be sent to email id to followup for login.
Sincerely,
Thiyaga
Aug 26, 2011 | Pinger iPhone Apps
I bought the DWL G710 range exender hoping to boast range for ipad use, so can't use CD and tried the internet address given in the manual but it does not connect. Apart from the connection problem that...
Connect a LAN cable from the D-Link to your computer's LANport, open a browser and enter the D-Link's configuration URL. OR open thebrowser on your laptop and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now configure the wireless settings .
Feb 27, 2011 | D-Link AirPlus G Wireless Range Extender...
192.168.0.30 for DWL G710 does not respond
hi r_raiche
1. Take a regular ethernet cable and plug it into the ethernet port of your computer
2. Plug the other end into ethernet port of the DWL-710
3. On your computer (assuming you have Windows XP Pro with the NON-classic start menu), go to Start > My Network Places
4. On the top left under "Network Tasks" click on "View Network Connections"
5. Right click on "Local Area Connection" and then down to "Properties"
6. A pop-up window with 3 tabs should come up. Under the "General" tab, there is a list of icons with checkmarks next to them. Highlight the "Internet Protocol TCP/IP" on and click the "Properties" button underneath
7. Tick "Obtain an IP address automatically" and "Obtain DNS server address automatically"
8. Click on "OK" then "OK" again
9. Open up Firefox (or IE) and type 192.168.0.30 into the URL field
10. Type in the default username and password
Jul 07, 2010 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 won't connect to 192.168.0.30
Here is a link to the manual for your DWL-G710.
D-Link manual on page 13 it lists the url entry should be
"http://192.168.0.30" This is a HTTP link not a HTTPS.
Also the address you typed in might be a typo. The IP address should be 192.168.0.30 not 192.168.0.30.
GOOD LUCK!!!!
Oct 18, 2009 | D-Link AirPlus G Wireless Range Extender...
MAKE PASSWORD
1- connect through ethernet
2- the default ip @ is 192.168.0.30 (check the manual :)), mask is 255.255.255.0 [make your pc in the same subnet]
3- enter the adress in your browser
4- default user is admin, default password is blank (nothing)
5- run wizard (click the button)
6-go to admin tab , you can set your password there
hope this helps, let me know
Apr 01, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
DWL-G710 keeps disconnection from router
sounds like it isn't working anymore.
try resetting it and configuring it again with the network cable
Dec 26, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
No internet connection via DWL-G710
Your extender may not be able to talk to the router. Make sure you have set default gateway in extender to IP of the router. Turn off encryption first. Check the router if extender shows up in active client list or active mac address list.
Oct 18, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Setup range extender
Access pointe bağlanmak için öncelikle bilgisayara elle ip adresi vermek zorundasınız daha sonra cihazı ethernet yoluyla bağlayarak ayarlayabilirsiniz.Ancak modeme bağlarsanız ip adresini ayarlamak gerekmez.Kolay gelsin.Good By
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
DWL-G710
check the dial-up configuration settings. via the admin web page for that DWL-710 gateway
Jun 27, 2008 | D-Link AirPlus G Wireless Range Extender...
DWL-G710
Move the repeater directly next to the router, connect to the repeater with a laptop/desktop and enter the configuration utility, see if you are even able to establish a "signal" status. If not, you may have a defective product or extreme amounts of emi.
May 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
1,262 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
