Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
Pool pump wiring
We unhooked our AO Smith switchless Century Centurion 2 HP pool pump to change the seal and now don't know how to hook it back up! :( There are 2 black wires and one white and we don't know which wire goes where? Here is a link to pictures of the wires, pump and pump diagram. http://picasaweb.google.com/monikakleinknecht/PoolPump02?feat=directlink
Please help !!
Thanks,
Monika
    Scholar:
  • 59 Answers
O.K. MONIKA READ VERY CAREFULLY!!!!
I DON'T REALLY LIKE TO GIVE 220 VOLT WIRING OVER THE INTERNET,LET ALONE THE PHONE,but I have a good feeling that if you all replaced the seal, you have an understanding of what you are dealing with: 1st make sure all power is disconnected,Breakers too(hey I have to say this so don't take it to heart), now the two black wires are 115 volts each, and the white one is ground, now enough said, the wires going from the source, (pool house,pump room), should be one white,one red, and one green, if this is the case the black and white wires, are the ones to hook up your black wires to, it does not matter (which of your black wires) go to either the red one or black coming from the source, and if your white on the motor is your ground it should goe to the green one coming from your source, if you don't already have them,I SUGGEST, you go to home depot,or lowe's and purchase the BLUE "water tight" wire caps, they can and are a "life saver anytime electrical is used around water, they cost some, but isn't a life worth a buck or two more? remember 115 volts can kill you if your around water 220-248volts will really kill you, so please check and double check all that I have told you. make sure everyone is clear,(pet's too), and flip the breaker, and you should be in business, god bless, happy 4th, and please let me know if I can help more
Posted on Jul 03, 2009
I'm replacing a 230v pool pump that previously had just a L1, L2, and ground connection which also ran from a timer. The new pump has L1, L2, L3, and ground -- no matter how connected the pump runs hot immediately by passing the timer. Help
Posted on Jul 08, 2011
Instructions to replace ao Smith Centurion Switchless Motor
less hassle replace whole pump if motor overheated ruined seals and possible distortion of pump
Apr 09, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
How to take apart a pool pump motor
if seals went bearings going shortly if bearings went seals shortly replace whole unit less hassle
Oct 11, 2012 | AO Smith A O Smith Motors Centurion 1/2hp...
My centurion pump is leaking
bad seals they are ruining bearings replace whole unit
May 17, 2012 | AO Smith A O Smith Motors Centurion 1/2hp...
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
Ao smith century 1 hp 56y pool pump sqeals for few minutes at start up and then is ok - sounds like bearings - unit 6 yrs - what is fix
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
Feb 06, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
2,802 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
