Question about Fisher and Paykel Refrigerators
How to replace a bulb in the f&P 325T fridge please?
  • Fisher and P... Master
  • 4,655 Answers
I will be getting you an answer as soon as I contact the company.Could find little information on the model and the model number. Please look for me so I can help you better, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
http://appliancepartseast.blogspot.com/
Posted on Jul 03, 2009
How to remove cover of fridge light to replace bulb
generally there is a Philips screw at the edge of the plastic cover,or sometimes you can squeeze or press in the sides of the cover.Check the make & model and go in line to the company,They usually will have a manual where you can find out the answer.Best of luck.
May 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
"FR-480" & "fridge light not working"
remove the plastic cover after turning off power to fridge. the bulb will be a screw in type and may be simply loose in the socket. If not remove the bulb . Replace the cover and get a new bulb turn the machine back on until you do Any electrical wholesaler will have one Take the bulb as a sample.
Apr 29, 2013 | Refrigerators
How to replace light in a Hoover D42UF fridge/freezer
go to local service center & collect 15w bulb.
May 30, 2012 | Refrigerators
My frididare (side by side) fridge light is not working, even after I have tried two different replacement bulbs. model no. FRS26R2AW4. Any help will be appreciated
Please check using a tester/multimeter for the voltage on the bulb holder or test if the bulb within is fused or not using a continuity test. If not the fault can be with the main door switch of the fridge - normally some switches fail and so there will be no contact. If not there can be break in the circuit line/wiring to the holder.
Getting the correct type of bulb please check on this link:
http://www.espares.co.uk/search/fridges-and-freezers/p/1084
Sep 02, 2011 | Frigidaire FRS26H5AS Side by Side...
I have a Hotpoint HMB313I integrated fridge freezer. When I open the fridge door no light comes on. Should there be a light in the fridge? If so, could you tell me please where the light(bulb) is located...
Hi!!
The light bulb is usually located in the center top of the fridge box, you may need to get on your knees and look up to see it. They usually just screw out, in case there is a plastic cover, just squeeze it and remove it. The replacement bulb can be found at Walmart or KMar it is call Appliance Bulb.
Good Luck!! Don't forget to rate this post!!
Jul 18, 2010 | Hotpoint Refrigerators
Removing bulb from fridge/freezer.
Usually the light bulb base is a screw, to remove it you need to rotate it clockwise (facing your fridge). I highly recommend you to use a towel to handle the lightbulb for safety reasons.
If you are replacing it, please be aware that you should use a 25W or 45W light bulb.
Hope it helps.
Sep 29, 2009 | Fisher and Paykel Refrigerators
Fridge Light - you posted
Your bulb is shorted out internally. Try another bulb. Please post as as helpful if so.TY
Jan 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
76 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
