Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Dishdrawer leaves dried detergent and crud on
Fisher&Paykel dishdrawer leaves dried detergent and crud on glasses and glass lids when it is finished. What is the solutio?
  • 784 Answers
1-Go to diagnostic mode.
2-Press the Start /pause button until you get the display rd for Rinse Aid Dispense setting.
3-Have warm water readu in a kettle or a pitch.
open thedispenser to pull water in.
press the Lock button to turn the dispenser on.
4-Continue to pull water onto the dispenser holder so it can flush out all the resisdue.
5-When you feel that it is enough, press the Lock button again tostop it.
6-Press the power button to get out of this mode.
7-Start a Rinse cycle to completely flush out the residue from the inner tube to the sewage.
8 The next run you won't see the white stuff anymore providing that you will use the liquid not the powder...
Posted on Jul 04, 2009
I don't know where to put the new Finish tablet in the Fisher and Paykel dishwasher. Where or what is the Dry Dispenser ?
Hello Susanna Davies,
Generally a round cap immediately next to the
washing powder dispenser...
Known as "FINISH" or "Jet Dry"... as it really does
keep spot off of your dishes & especially glassware.
Amazon com ishwasher dry agent Tools Home Improvement
I tried to look up Fisher & Paykel...
but without a specific MODEL NUMBER
I could not pull an OWNERS MANUAL to demonstrate.
look here for FREE documentation
ManualsLib Makes it easy to find manuals online
SEARS is the last place I would recommend buying parts
(but that has more to do with integrity & respect)...
Their parts, guarantees & prices are suddenly competitie
Dishwasher Detergent Dispenser Part Number 526860 Sears PartsDirect
Hope this helps
Carnac the Magnificent
Sep 23, 2017 | Fisher and Paykel Dishwashers
Fisher Paykel Nautilus dishwasher
There is a drying cycle that runs for around an hour once the DD has finished its final rinse . It should show it on the LCD
Jun 03, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Dishdrawers display F1 fault, what do I do?
The flood switch at the base of the dishwasher (under the bottom drawer) has triggered. This means water has collected at the base of the dishwasher housing. This can happen for many reasons, leaking drawer lid seal, broken drain hose, broken water inlet hose, etc.
You will need to find the source of the leak. Also incorrect detergent can cause foaming which triggers the flood switch.
Turn the mains power to dishwasher off and take the cable out of the socket. You will have to find a way to take the bottom drawer out. Usually it needs a plyer to pull out the plastic fasteners one on each side. Slowly take the front cover out and lift the drawer off the rail and bring it out.Make sure the controller or display panel do not fall out. Use masking tape to hold these in place. Leave it on the floor without tugging too much on the cable and hoses. Dry the base with towels and hair dryer. The flood switch is mounted on a circuit board located in the base.
Put everything back and conne power and try again.
Hoses need to be replaced if these are source. Also lid seal can be replaced if this is the cause.
Use recommended detergent. (no power balls) or tablets.
good luck.
Dec 15, 2012 | Fisher Paykel Fisher & Paykel DishDrawer...
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
May 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
My Fisher & Paykel dishdrawer dd603 is flashing f1
the flood switch at the base of the dishwasher has been activated. This means moisture has gone into the base (under the drawer).
Turn power off, and extend drawer to expose bottom back of the base. Use towels / hair dryer etc to dry it out.
Likely causes are - you used a wrong detergent (too much foam) or the hoses at the back are leaking or the actuator arm that supports the hoses when you pull or push the drawer is broken and the hose is kinked.
Hope you can fix it.
Dec 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel leaves film
When a film is left on the dishes, the problem is almost always a failed heating element. Dishwasher detergent requires a high temp to fully disolve and be effective as a a cleaner (solvent.) When the element does not come on during the wash cycle, the detergent is never activated.
It is ~possible~ that the thermister has failed, but some sort of error code should be reported if that was the cause.
Good Luck! Please report back what you find. OK?
May 06, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Do not know how to add dishwashing liquid to machine
Fill your clean, dry dispenser cup with detergent and close it.The water streams through the closed dispenser and comes out at the bottom of the dispenser. Make sure you have 120 deg f water coming to the dishdrawer and never put anything in that dishwasher that is to tall or comes up above the drawer when you start the dishwasher it has a lid that comes down and if it does not seal you will get an f1 code and it will require a tech.
Mar 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Possible pump blocked
dishes have white film glasses are foggy
Jan 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD602 burning smell
What is the Jet Dry? if you mean rinse aid, then no this light means that you need to put in more rinse aid
Mat
Aug 04, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
467 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
