Question about Homelite Mighty Lite Lawn Trimmer
String head removal UT-20501 (ST 200)
My deceased father in law had a ST 200 weed string trimmer. We got it when we bought the farm. I can not figure out how to remove the string head to replace it with a newer head.
  • netyet Jul 04, 2009
    unscrew bottom retainer (left hand thread)
trippssmengi
  • 76 Answers
SOURCE: replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Posted on Jan 05, 2009
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
#1 Taper
  • 1041 Answers
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
#1 Taper
  • 1041 Answers
SOURCE: Installing new line on my string grass trimmer
Jim
Posted on Jul 03, 2009
#1 Taper
  • 1041 Answers
SOURCE: How to change the string
If it is a duel line trimmer then:
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
ST200 trimmer. What kind of spark plug to get and what size string does it take?
Hi Cherri,
I think this is the manual for your machine. It should tell you all you need to know:
file:///C:/Users/Jim/Downloads/Homelite-String-Trimmer-Parts-Manual-ST200-String-Trimmer-UT-20501-A.pdf
Good Luck!
Jim
Sep 02, 2015 | Homelite Garden
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
Shaft heating up next to trimmer head- smoking polan pro150- and how to remove head for service
You can wrap a rag around the threaded end of the string head shaft after removing the bump knob to hold in place while turning the upper part of the string head counterclockwise to remove. Then you can do the same to remove the metal shaft adapter nut above that, exposing the flex shaft in its entirety.
Aug 14, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Pulling string on weed eater does not want to turn
It's possible that the engine has seized if the pull cord won't turn the engine over. Remove the starter mechanism from the engine and try to turn the flywheel by hand. One or more of the mounting screws may be hidden under a decal or other label. If the engine won't turn at all, remove the muffler and check the piston skirt for bad scoring--which usually means either dirt inhalation (bad air cleaner) or running the unit on straight gasoline. Either of these conditions require replacement of the cylinder, piston and ring(s) plus labor if you farm out the repair. Weigh the approximate cost of up to $150 against a new trimmer. Hope this helps!
Jul 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
St1000/type 1 grass/weed trimmer - How do I remove the head?
Yes, there should be a lock hole on the base of the bump head, spin around until both holes align and stick a pin through them both and the base will be locked.
Now spin the head off.
The new one will come with adapters if you need them.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
Jun 14, 2010 | Black & Decker String Trimmer Cordless 12"...
Have a Ryobi weed wacker 725r 31cc click link Trimmer Plus. No more line-can't figure out how to remove bottom to replace the line or what kind of line to replace with. Deceased husband lost directions...
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Jun 09, 2010 | Garden
I don't know how to load line into the Troy Bilt Speedlock head
cut to pieces of string about 8 ft long. run your line through the holes on the side of the head. you will see 2 smaller holes on the inside. put the string in those 2 holes and begin turning your head to install the string.
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Can not remove head to install new string...HELP
you need to turn the knob on the bottom clockwise-also if that doesnt work it could be just stuck try using a pair of vise grips to loosen
Aug 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
399 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
