Question about HP Computers & Internet
Cant fix DirectX 3D Accelerator
I have been trying to get the 3D accelerator for directx to work for 3 days. I have uninstalled directx, reinstalled it, ran updates, updated my memory card! I am going nuts. Someone please help.
  • ELYSE DAVIS
    ELYSE DAVIS Jul 04, 2009
    MICROSOFT WINDOWS XP PRO VERSION 2002 SERVICE PACK 1
    AMD ATHLON(TM) DUAL CORE PROCESSOR 4450E
    2.30GHZ 2.87GB OF RAM
  • FoxSysTech
    FoxSysTech May 11, 2010
    We will need a full range of specifications for the computer as well as the OS you are using, what service pack. etc. Unfortunately, directx, video and such things are very picky about what they will work on. Sometimes there are work-arounds, but we will need these specs.
  • 630 Answers
If you're really running on SP1 I would seriously say you need to go on Windows update and get up to at least SP3. The have been a lot of Direct X updates since then as well.
Posted on Jul 04, 2009
I need 3D accelerator
Direct3D is a component of Microsoft's DirectX graphics software and is one of the more commonly used graphics accelerators in PC gaming. Of course, before you can enjoy the benefits of Direct3D acceleration, you need to have that particular component enabled in DirectX. Fortunately for your gaming needs, enabling Direct3D acceleration is not an overly complicated process, and can be achieved in a matter of moments. Open the "Start" menu and type "dxdiag" into the Windows Live search box, then press "Enter." This will bring up the "DirectX Diagnostics" dialog box. Click the "Display" tab. Locate the "Direct3D Acceleration" entry. Click the "Enable" option next to the Direct3D entry. This will turn on Direct3D acceleration. You may need to restart your computer to make the changes effective. Hope this helps. http://www.microsoft.com/games/en-us/aboutgfw/pages/directx.aspx http://ati-catalyst-drivers.en.softonic.com/ Optimise your ATi graphics card's performance b> http://download.cnet.com/3dmark2001/3000-2121_4-10056689.html
Jan 09, 2013 | Toshiba Computers & Internet
How i download direct 3d device 9?
"direct 3d device 9" is the directX for Win98. For Windows 98 you have to install DirectX 8.1b. If you graphic card does not support 3D function you will not have "3D acceleration".
For DirectX 9, try this link @ http://www.falconfly.de/directx.htm
Hope it helps.
Aug 27, 2011 | Microsoft Windows 98 for PC
I am having a problem. I downloaded the game, Battlezone 2, and installed it. Ive downloaded it from several different sources and am running into the same problem. When I load the game it says "Can't...
Direct3D 6? Wow, the game must be way older than your computer. You probably installed DirectX 10 or later. There were major changes after DirectX 9. The software routines to manage graphics hardware acceleration through DirectX 10 or newer are probably very different from DirectX 6, so the game's graphic controller interface can't find them.
Try going into the game properties (right-click on the main executable file and select Properties from the pop-up menu).
Set it to run in XP compatibility mode and see what happens.
Check to see if the game has the option to run without hardware acceleration. If this provides acceptable performance, that is your answer.
If necessary (and if Microsoft still makes it available), try installing DirectX 6. Vista may snag on it and make you remove it and reinstall a newer version, but it's worth a shot if the other fixes don't work.
Jul 03, 2017 | Activision Video Game Consoles & Games
When i last install Adobe Photoshop its ok... but after i reformat and try to install its ok also... but when i run... IT says Direct3d not supported... on the last reformat the directX is working fine...
It's important to let me know the operating system installed on the system with the system configuration. I will be glad if you can at least reply my post with those info.
I guess you are running windows Xp with the chipset which doesn't support Direct X 10 or newer version. Or in other words, windows vista or windows 7 with incompatible chipset for directX newer version.
First uninstall the currently installed DirectX and reinstall Direct X 9. You have to uninstall the currently installed direct x properly, and it's also important to clean the registry after it's uninstalled. After it's removed, restart your computer and reinstall Direct X 9. That'll definitely fix your problem.
If you need my further help, let me know with the details i've mentioned above so that I can help you better and with easiest instrucitons/methods.
Good luck.
Thanks for using FixYa.
Aug 30, 2010 | Adobe Photoshop CS for PC
Direct x features - direct draw acceleration direct 3d acceleration AGP texture acceleration are missing. how can i get?
hi, check whether directx is installed. type this command in run DXDIAG.
If you running XP it would be directx 9C and for Win 7 directx 11.
if you want downland directx latest visit microsoft.com/directx
Jun 14, 2010 | Computers & Internet
In DirectX Diagnostic Tool under DirectX Features, it shows that Direct3D Acceleration is Not Available. I uninstalled and reinstalled my Nvidia drivers and I no longer can run 3D software. Please advise.
Hello there:
this is normaly due to to a 3d accelerater is not installed your ndivia driver would really not have any thng to do with it
What i recommend that you do is to go to the web and download direct x 10 this is the latest and updated direct x that works well with operating systems ok
I hope that this has been very helpful for you
Best regards Michael
Nov 16, 2009 | Microsoft Windows XP Home Edition
I am trying to play 18 wheels of steel and when i try to play it a prism3d error come up and is unable to load how do i fix this problem?!!!
Here are the minimum requirements:
Operating System: Windows® 98/ME/2000/XP
DirectX®: 9.0
Processor: Pentium® 4 1.2 GHz or 100% compatible processor
RAM: 256 MB
Hard Drive Space: 500 MB Free
Drives: CD-ROM 4X
Display: 256 Colors
Cards: 32 MB 3D Video Accelerator with DirectX 9.0 compliant video drivers
The most common problem is a lack of a physical video card. Onboard video cards can't produce the graphics properly, and generally encounter problems.
Nov 04, 2009 | Microsoft Windows XP Home Edition
Autocad problem
Sounds like you need the latest version of directx installing.
Get DirectX from Microsoft here >>>>>>>>>
http://www.microsoft.com/downloads/details.aspx?FamilyId=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
To check to see if your 3D accelerator is enabled go into DXDIAG (type DXDIAG in the run or search box),
go to the DISPLAY tab, see if Direct3D Acceleration is ENABLED.
Finally make sure that you have the latest video drivers installed
Regards.
Aug 03, 2009 | Dell Latitude D600 Notebook
My pc is failing to pik directX 9.0 graphics
you need to fix the extrwinedpc.exe error located in the directx folder.
or open run and write exwindirxxp.exe. Then follow the instructions.
Jul 21, 2009 | IBM Computers & Internet
3d direct device
I think ya need to enable DirectX So, to enable DirectX, you must first enable graphics acceleration. To do so follow the next steps: 1. Right click on the desktop and go to Properties, Settings, Advanced, Troubleshooting. 2. Set the Hardware acceleration bar to Full. 3. Click Ok all the way out. To activate Direct3D and DirectDraw (DirectX) follow the next steps: 1. Go to Start/Run and type "dxdiag". 2. Click OK. 3. Click on the Display tab, then click on the Enable button for DirectDraw and Direct3d. 4. Click Ok all the way out.
Aug 17, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
213 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
