Question about Boating
Dont know wich wires go to wich prongs on ignition
1978 jhonson 70 horse outboard ignition switch wires 6 prong igniton switch what does the purple white wire go to and black yellow and red purple andyellow red and purple and black
  • 23 Answers
You can get a wiring diagram by going to a web site for OMC Motors
Jim OMC Retired Mech
Posted on Jul 07, 2009
It is the switch in the 2006 cavalierfema trailer above the sink I need to put the switch in but dont know what color wire goes where there is 4 prongs on the switch itself but has 2 red wires 2 purple...
With todays phones, it is always best to take a pic of the actual wiring hookup... Go to google, maybe they have a wiring diagram for it.
Aug 13, 2017 | RVs
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
Jeep grand cherokee 1996 changed out sensor but now it reading max on 80 psi. Why
Your old one had one wire connector and one prong, the new one you put in has two prongs on the switch and the connector so what did you do with the extra wire on the new plug? You put the new two prong switch with the old one wire connector.
this may be an update or wrong part, why dont you go to an autoparts store and get the switch, tell them you have a gauge.
let me check this out , just give me a minute ...............
Okay, i checked this out and there are two different switches
the two prong is for the gauge and the one prong is for the light.
I know you have a gauge, return the switch and sensor they are wrong that system only has one wire, the problem is that this jeep a 1996 has a 1995 engine in it, that happens all the time when they are making any type of car or truck, go to the auto parts store and tell them you have a 1995 jeep grand cherokee with a 4.0 engine and you need an oil pressure switch and you have a gauge, they should hand you a single prong switch. put it in and let me know what happens. good day.
Dec 25, 2012 | Cars & Trucks
No fire to the plugs looks like the man owned it befor me put the 100 hp evinrude on it it should of been a 175 jhonson..jhonson plug has 2 extra wires.. can you please help
You will need to compare both engines wiring diagram. These engines would bolt to the same intermediate housing over an astonishing wide range of powerheads.
You may have completely different ignitions.
Oct 04, 2011 | Clymer EvinrudeJohnson Outboard Shop...
97 buick sky lark, replaced the starter. There is a two prong connection yes yellow and purple wires. Cannot find were it goes ?
The purple wire should be from the ignition switch. It would go to the "S" terminal of the starter solenoid.
You may also be able to look up a free wire diagram at Autozone.com in the repair section.
Sep 09, 2011 | 1997 Buick Skylark
Don't know how to switch from 4-prong to 3-prong power supply
Your new 3 prong power cord needs to be wired up just like the 4 prong you just dont have the seperate ground . in the use of a three wire cord ground runs thru neutral .Hook black to black on the terminal block on unit. hook red to red on the other side of block and white to white or green in the middle reinstall the cover ....Plug in and your ready to dry
Aug 14, 2010 | LG DLE2532W Electric Dryer
We have a kenmore 70 series electric dryer, and we have a three prong receptacle, but the plug is 4 prong. What type of adapter do we need?
According to the National Electrical Code, as of 2000 all newer homes are required to have a 4-prong receptacle for all 220VAC appliances. However, if your home already had a pre-existing 3 prong outlet, you shouldn't have to upgrade to a 4 prong. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the neutral (WHITE) and green (GROUND) wires are termnated. In a 4 wire configuration, the neutral and ground are independent of each other. In a 3 wire configuration these two wires are terminated together. The instructions to convert a 4-prong appliance to a 3-prong are at the bottom of the page in the link I provided.
NOTE: If this is a new dryer, keep in mind, some REQUIRE a 4-prong plug even if you have a pre-existing 3 prong outlet. Read through your installation instructions that came with the appliance if in doubt. If this is the case, you will need to have a 4 wire outlet installed by a certified electrician.
If you have questions, please let me know. I hope this helps you.
Aug 02, 2009 | Dryers
Won't start
maybe a short that's causin it not to start
May 27, 2009 | 1995 Chevrolet Blazer
Boating Logo
395 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
