Location of dm module on wd-62725 mitsubishi 60 in. tv
    President:
  • 1,779 Answers
The digital module is bolted onto the light engine. If you are not a tech, you are in for a real treat. I checked for availability and it said No Longer Available. They want the DLP sets off the market.
Posted on Jul 03, 2009
Tv wont power up after replacing 6 caps 4 bad 2 looked good but were in series so replaced with larger voltage. mitsubishi wd 62725
That model will usually have 8 caps that require replacement on the Power board and also 4 capacitors on the DM board which will usually cause the Non stop blinking light symptom.
Sep 23, 2011 | Mitsubishi WD-62725 62" Rear Projection...
WD-62725 Put new bulb in, plugged up tv and get a green flashing timer light. TV does not come on.
Replace the DM capacitor. You can get the V26 DM rpair kit from www.tvrepairworld.com which has the replacement capacitors and the CD with detailed repair instructions.
Dec 25, 2009 | Mitsubishi WD-62725 62" Rear Projection...
WD 62725 timer light continusly flashes green TV won't turn on! Push reset button as soon as you release it ,it starts flashing again. Unplug TV 3-4 Hours No help.
The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacement capacitors and the step by step instructions on CD
Dec 07, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Tv won't turn on?
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Dec 27, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Blinking light will not turn on
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
May 06, 2008 | Mitsubishi WD-62725 62" Rear Projection...
WD-62725 DLP TV Automatically Turns Off
Its usually your DM control board!!! it needs to be replaced!!!
Mar 29, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
