Question about Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L
My Bosch Model #3915 10" mitre saw in the past week has started sqeeling when I let off on the switch. Is it the brake or bearing or somethong else Thanks Steve
  • David Ford
    David Ford May 11, 2010
    I would remove the blade and flanges and try it without them and see if it is still there. Also when removing check the tightness of the blade it could be loose and spinning freely when coasting. It could be a couple things bearings first and then from there gear noise. How old is the tool and when was the last time it was serviced and the grease checked and or replaced. Let me know if I can help further and I will try and come up with more suggestions
    Problem Solver:
  • 10 Answers
This is definatly the armature bearings bearing mate
Posted on Jul 04, 2009
My Bosch Mitre Saw is starting to squeal a bit when I start it. Any suggestions?
I had the same problem with my Bosch. I ended up removing the new belt and cleaning the entire belt pathway. It works fine now, I never saw any debris or problems.
Jan 04, 2014 | Bosch Saws
Ryobi 10 in Mitre saw with laser, switch / motor wiring diagram?
capacitors are known as capacitors or condensers. Both do the same job of storing electrical energy and then releasing it when the current flows back . They are used to either start an electric motor or stop arcing on the brushes by absorbing the current flow as it stops over each commuter bar of the armature
Dec 02, 2012 | Ryobi 10 In Miter Saw With Laser
Mitre saw running, but not switched on?
there should be no power going anywhere until you pull on the trigger. With that in mind I would be looking at the switch for the fault
Macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
Feb 26, 2012 | Saws
Electric blade brake sounds like it is seized up. Upon starting table saw (bosch 4000), motor sounds like it is binding. How can I disengage the brake??
There is no electric brake on the Bosch 4100 table saw. If the motor sounds like it is being held back its possible the rear armature bearing has seized or the field coil is faulty. Both these problems cause the motr to not turn at full speed. The motor must be serviced.
Dec 08, 2010 | Bosch 4100 10" Worksite Table Saw
Bosch gsm 10 compound mitre saw. which way does the screw turn to undo blade
On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
Jul 26, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
Motor replacement for Bosch Mitre saw
Most often the entire motor doesn't go bad. It would be a componen't like armature, field, brushes, Switch. I very seldomly see a whole motor go bad. look for a single problem. The saw is not junk it is very repairable with some testing of parts.
Jul 12, 2010 | Bosch 10" Slide Miter Saw
I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Mar 15, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Mitre saw runs in wrong direction
You have inadvertantly crossed the wires to the motor.
Feb 16, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L Logo
386 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
