most likly you sucked something into (auto) water leveler, try unplugging unit and check drain hose,also drain hose HAS TO DRAIN "UP" ATLEAST 36 INCHES, off of floor into sewer line, or it will back up into washer,thus not completely emptying last cycle, let me know if this helps,god bless
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Duet GHW9150P Front
getting flashing F11 on Whirlpool Duet front load washer -- stuck /locked before cycle finished,...
(More)
getting flashing F11 on Whirlpool Duet front load washer -- stuck /locked before cycle finished, will not reboot by following directions so apparently I get to spend more $$$ on top of what I spent to buy the thing. So much for paying top dollar to get a good machine and avoid problems!
I presently am on my second Whirlpool Duet Front Load machine. I love it, however, 2 machines in 4...
(More)
I presently am on my second Whirlpool Duet Front Load machine. I love it, however, 2 machines in 4 years is a bit expensive. When the spin cycle comes on it sounds like it's spinning rocks. This was the problem with both units..What's the deal?
the water was off on my font load washer...i didn't know and turned it on went down later and a code...
(More)
the water was off on my font load washer...i didn't know and turned it on went down later and a code was flashing...i pushed the button and now i can't get the cycle to work or to cancel the cycle...what should i do? i tried to unplug it but the same thing happens after i plug it in
There is left over water in the soap, bleach and softener containers after running loads of laundry....
(More)
There is left over water in the soap, bleach and softener containers after running loads of laundry. I've tried to clean out the dispenser area inside the washer, but it keeps happening with every load.
