Question about Sony VAIO PCV-RS422X PC Desktop
Hard drive When booting up my Sony Vaio PC, I am getting a message saying "immenint hard drive failure".What are my options at thid point? Is there anyway to save what I have on the hard drive, or to get the stuff off on to another hard drive?
  • 57 Answers
Try first to replace the IDE cable or unplug ang re-plug the cable and if doesn't really work you should repalce the hard disk.
Other suggestion is to run the repair. On the command prompt execute the chkdsk from the C:/
Maybe this will help!!
Post your rating.
Posted on Nov 10, 2007
  • 78 Answers
I would at this point not attempt to boot to that harddrive. replace the harddrive and after you have the operating system installed you can slave that harddrive in and copy the data (maybe)
when you reconnect the harddrive go for the documents you want the most first
When i open my acer 4047 just displyd for setup key f2/f12 to pres,then i press f12 to reinstall new windows but there is i dont fine any hard drive?
Seeing as this is an approximately 8-year-old laptop, if you are getting a message that no hard drive is found, you have one of two issues.
Either your BIOS has reset itself and is not looking at your internal hard disk as the boot source and the message is not hard drive not found but boot disk not found .... OR ..... your hard drive has suffered a failure and needs replacement.
Jan 14, 2012 | Sony VAIO PCG-K25 Notebook
Disk boot failure.insert system disk. Message that appear a boot up
first of all check in your BIOS whether your motherboard is detecting your hard drive or not.
If yes try installing window.
If not it means your hard drive is not detected , Open the case and check hard drive data cable is connected properly or not, and hard drive is getting proper power supply.
you can try changing hard drive data cable and power connector from.
If still you are facing the same problem that means your hard drive gone bad.
Jun 15, 2011 | Sony VAIO PCV-MXS10 PC Desktop
I have a sony vaio pcv-L400 when I turn it on it says: disk boot failture, insert system disk what can I do I dont have the system disk
That message means that, for one reason or another, the computer can no longer see it's hard drive. The hard drive may have failed, or it might just not be firmly connected (especially if you recently moved the computer).
Sep 15, 2010 | Sony VAIO PCV-L400 PC Desktop
Sony VGC RA710 wont boot
boot from your original cd and choose repair windows
Oct 25, 2009 | Sony VAIO VGC-RA710G PC Desktop
Sony vaio pcv rx680g desktop
First, ensure that the bios is reading the hard drive and that the hard drive is part of the boot sequence. If you have a known working drive and the drive is not been read by the bios, you will get the Disc Boot failure error because windows resides on the disc which the bios cannot access.
Secondly, if the bios is reading the disc then ensure that the disc is set as part of the boot sequence-preferably the item after DVD drive should be Hard Disc in the boot menu.
If both of these items are in correct order then you could have a bad boot sector on the drive. Run a C:Chkdsk. If no bad sectors are found try C:Fixmbr-ensure that the Windows installation disc is in the CD/DVD drive when running Fixmbr.
If that fails do a clean install of windows.
Good Luck
Sep 28, 2009 | Sony VAIO Digital Studio PCV-RX680G...
Sony Vaio desktop will not load windows
what your describing is a hard disk failure the computer cant or wont read the hard disk to boot the machine, so it shuts down. Sounds like the hard disk died from a bad virus. and the computer wont run. Best I can do for you is either format the Hard disk and reinstall the operating system or buy a new hard disk. Cheers
Apr 01, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
Sony vaio pcg-fxa36 will not boot get error realtek RTL8139(A/B/C
ok, what is happening is the laptop is trying to boot from the ethernet port, what you have to do is go into the bios (this is usually F2 on boot) and change the boot order to hard drive, save settings and exit the bois screen, the pc should now boot to windows
kind regards and please don't forget to rate us
Dec 03, 2008 | Sony VAIO FXA36 Notebook
Vaio error message
This generally indicates a hard drive failure, but occasionally it's just an operating system glitch. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a fresh operating system. If you have any problems during or after the format or install, then the hard drive has failed and will need replaced.
Jul 24, 2008 | Sony VAIO GRX550 Notebook
Toshiba satellite pro l40 boot up problem
If you run a repair with the recovery disc you won't lose any info. The only time you'll lose the info is if you run a complete reload. Run the system disc until it gets to the point of finding installed operating systems, at this point instead of deleting the partition, press R and it will reinstall the operating system files only leaving other installed files and programs intact. Keep in mind that many times when this happens, it's a hard drive failure. If it is a hard drive failure, then you will have to replace the hard drive and you will lose the info, sorry.
Jul 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Sony VAIO Z1WAMP3 PC Notebook
 Boot to get rid of the problem or repair your HDD.
Jan 26, 2008 | Sony VAIO Z1WAMP3 (PCGZ1WAMP3) PC Notebook
Sony VAIO PCV-RS422X PC Desktop Logo
79 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
