Question about Estate EED4300TQ Electric Dryer
Motor is running but not turning drum to dry the clothes. We removed the back of dryer to see if maybe belt slipped or broke but can not see any belts and do not want to start removing a lot of screws without first knowing where to look.
    President:
  • 1,865 Answers
Look from the rear, near the bottom. The belt wraps around the drum, and near the bottom is a tensioner that keeps tension on the belt. If it is broken, you'll see it laying on the floor of the dryer.
Posted on Jul 03, 2009
Dryer drum not turning
First...just as a reminder that electricity can kill! Unplug the dryer and slide it out so you can get to the back of the dryer. Remove the back panel. Plug the dryer back in and observe the dryer in operation. If the belt is broken you have your obvious answer. If nothing happens then UNPLUG the dryer again and reach in and remove the belt from the motor. Plug the dryer back in and attempt to run it again. Does the motor spin? If not, dead motor. It is not the thermal fuse because you say it heats up. Take a look at this video for additional help.
Nov 29, 2017 | Samsung SM-DV210AGW - SERVICE MANUAL
I used the dryer last night with no issue. When I went to use it this morning, I pressed the start button, I heard the motor run, but the drun did not move. After a second, the motor stopped trying. ...
i would say the belt that turns drum is broke,slipping or jumped off motor.try running without clothes in it.if drum dosent turn belt is broke or off
Oct 22, 2013 | Electrolux EIED55H Dryer
My dryer drum does not turn during drying. The belt is not broken and the dryer is heating the cloths. Why has the drum stop turning?
You could have a faulty motor, or maybe the belt has slipped off of the idler pully or motor pully
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley, or maybe a faulty motor.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer some slide off.
Be real careful not to knock any of the wires off of the timer switch.
Then remove the top of the dryer,some are clipped on,others slide off.
Remove the front of the machine, this will expose the belt and drum, remove
the drum and belt and this will expose the drum rollers, idler arm bracket
with pulley, and motor with pulley.
Pay attention to the route of the belt,this will come in handy when you go
to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor pully causing the drum
not to turn.
If you cannot find the proble there, then maybe the timer switch is faulty and needs replacement.
NOTE:
While you have the drum out, I would recommend that you lubricate the drum
rollers at the shaft of the roller with a good grade of machine oil like 3
in One oil. This will save you a problem later with the rollers getting
noisy, also check your drum rollers for flat spots, if they have flat spots
on them this will cause a noise like a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Free answer...Please rate me
Dec 06, 2010 | Dryers
I have a frigidaire gallery 49012/59012 dryer and the drum want turn. The belt is not broke and the motor runs. I can see the belt is not turning on the drum. Is the belt maybe stretched or what?
You may have a belt motor problem. Turn the drum by hand and if it turns freely the belt is off at the motor pulley. You can try to connect it back on the motor pulley but what caused it to come off first off. Your belt may be bad or the pulley assembly may also be bad. You'll have to pull out the dryer and remove the back panel to see and repair. Good luck.
Jun 28, 2010 | Dryers
My clothes dryer squeaks when it runs. If I dry
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 19, 2010 | General Electric DCVH640GJ Gas Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
The drum doesn't turn on my dryer, why?
A couple of possibilities:
There is a belt that goes around the dryer drum. It may have broken or slipped out of place. If you remove the top of the dryer (usually pretty easy), you will probably see the belt going around the middle of the drum. (If not, maybe it broke.) It is loose? If so, it probably slipped off the motor or is broken (as you may find if you pull on it). If all this seems ok, you need to remove the front of the dryer. That's usually a little more complicated, but not too bad. Now you'll probably see the motor. On mine, it is on the lower right. Does the belt go around the motor pulley and the drum and is tight? If so, maybe the motor is broken.
At this point you need to know if the motor works, but that may not be really easy because opening the door usually breaks an interlock switch that stops the motor from turning. But if you are careful, especially with electricity, you may be able to bypass enough things to see if the motor turns. Alternatively, note the exact position that the motor pulley is in (mark it if necessary). Then reassemble the dryer, try to run the motor, and then open it again. Did the mark move?
At this point, you probably have enough information to see what needs to be fixed or replaced. One additional problem I had was that the motor pulley was slipping on its shaft. If a plastic/nylon part has broken, you may need to replace it. Of course, if the motor isn't turning, make sure that nothing is jamming it somehow (like a stray sock tightly caught in the belt). Hope this helps.
Jun 21, 2009 | Kenmore 62602 Electric Dryer
Dryer belt broke on my dryer.
I use a putty knife to press against the spring clips to pop the top. Then I use a quarter inch nutdriver to remove the screws holding the front panel on. I remove the wires from the door switch and lift out the front panel. I remove the drum and put the dryer on a work bench or a tailgate. I inspect the blower wheel(most of the time they get loose). I get the ball of lint out of the front panel filter housing. I vacuum out the dryer with my shopvac. I oil the rollers and idler and inspect the drum slides for wear. I loop a new belt rib side down to the drum and set it back in the dryer. With my left hand I drop the belt under the motor pulley and raise up the idler looping the belt on it and let the tension hold the idler. I manually slowly turn the drum to make sure the belt is secure and not twisted. I place the front back on. Snap the top down and give her a try. Piece of cake.
Jan 11, 2009 | Maytag PYE3300 Dryer
KENMORE DRYER PART NO 696891
are you sure belt not broke remove screws under lint screen and pull top up by releasing clips under edge each corner..is motor running ? also belt may have jumped off idler pulley and motor pulley remove front panel to ck
Oct 24, 2008 | Dryers
Estate EED4300TQ Electric Dryer Logo
131 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
