Question about Crosley CFUM21LW 20.6 cu. ft. Upright Freezers Manual Defrost with 4 Wire Sh
How can I adjust an upright freezer door ?
The door is lower on top left corner and I'd like to adjust it to ensure the best seal. Have had problems previously with it not sealing tight on bottom left side of door
    Dedicated:
    Visited the website for 20 consecutive days.
  • 436 Answers
Hello there,
It is always the feet and their adjustment and floor must be level
From the user guide it says
;The freezer must have all bottom corners resting firmly on
a solid floor. The floor must be strong enough to support
a fully loaded freezer.
NOTE:It is VERY MPORTANT for your freezer to be level in order to function properly. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems.
To level Upright Models:
After discarding crating screws and wood base, use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, half a bubble higher, so that the door closes easily when left halfway open. ;
User guide here
http://crosley.com/assets/product/1707/useCareGuide.pdf
Posted on Sep 24, 2014
SOURCE:
Have a upright freezer and the meat on the top shelf is thawed out but the rest of the food on the lower shelves are frozen. Is it a vent problem
Either the door seal is bad or the freezer has a refrigerant leak or a bad compressor. Best to have an appliance tech check it. It won't take him long to locate the issue.
Nov 04, 2017 | Freezers
Why is my upright igloo freezer not staying close
The door sometimes warps and need to be lightly twisted back to where all four corners make contact and seal.
Your unit may need to be tilt back a bit so the door wants to close y itself, the front foot pegs are adjustable and can be turned to make the front higher or lower than the back side of the cooler, gravity closes the door when the unit is leaning back.
Aug 28, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How do you adjust upright freezer doors? After releveling, the lower opening side corner is sticking out a little and seal is not quite touching, 1/8th".
pull door seal back exposing screws loosen slightly twist door ie. put foot at bottom of door and push or pull top of door.close to see if door mates up good if so tighten screws
Aug 29, 2010 | Freezers
Top is frozen lower shelves food is dethawing
One of two things is going on here, either the door is not closing properly (or some one left it open), check the seal all the way around especially at the bottom.
Or most likely you have a refrigerant (freon) leak that has left the charge low enough that you are unable to get it to cool throughout. A leak on this type of unit is usually in the evaporator in the corner where a weld was made. The evaporator is about $189.00, with refrigerant a new drier and supplies I bet it would run about $450.00 to repair.
Apr 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
New freezer has bad door seal
it often works to warm the seal with a hairdryer and reshape it
Nov 29, 2008 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Freezer door won't close at top
If you are careful, open the door 90 degrees and place your leg against the bottom corner inside of the open door and your hand at the top corner, then GENTLY push inward. You should be able to feel and see the move or twist. Then close the door to test for proper sealing. Another way to adjust the door is to loosen the screws behind the door seal and twist,but this usually unnecessary if you do the leg trick properly.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0100_34.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 16, 2008 | Freezers
Crosley CFUM21LW 20.6 cu. ft. Upright Freezers Manual Defrost with 4 Wire Sh Logo
763 people viewed this question
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
john h
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
