Question about Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder
I unplugged the power cord by accident. Now it doesn't work.
I unplugged my receiver from the power by accident and after I plugged it back, it doesn't want to work. The fan is running and I can see the red light coming from the optical audio input. On the front of the receiver the power light is off. Now, this receiver has no power button. Only a stand by button. Somebody knows how to make it work again?
  • marcokar76 Jul 04, 2009
    Ok. I posted this problem. And I got it working again. This is what I did: I unplugged it from the power for 2 hours to demagnetized the unit. Then I plugged it back to the power and pressed the stand by button for 10 seconds. Nothing happened yet. But, after like 30 minutes the power light was back on. I turned the TV on and I had signal and everything else. All my saved programs were there.
    It's just reacquiring all the viewable channels little by little but after one hour I got like 80% of them.
    I'm not sure if this procedure is the one for this problem, but it worked for me. So, if you have this problem, give it a try. What's there to lose??
I had to replace the power supply in mine when it did that.
Posted on Aug 31, 2009
What could be the cause of the receiver act like it's not plugged in? No lights or anything.
Is the outlet live? Does something else plugged into the same outlet work?
Does the receiver have a master power switch on the back that may have been switched off by accident.
Some - not all receivers have user replaceable fuses. If you do not see a fuse holder on the receiver near where the power cord attaches then you may need to open the chassis to see if there are replaceable fuses on the power supply board inside. Follow where the power cord connects to the chassis. It will lead to a board with a transformer that changes high voltage to the low voltage that the receiver needs to operate.
IF there are user replaceable fuses inside they will be on the power supply board.
PLEASE make sure that the unit is unplugged and has been for some time as the transformers sometimes stores residual voltage that will harm you. Don't do this unless you know what you are doing inside the unit. I recommend novices just take it to the repair center.
Also - IF you replace with the wrong fuse type and rating you can cause further damage to your unit.
Good luck and be careful.
May 26, 2014 | Sherwood RD-6108 Receiver
My 1507 singer machine wont power on
try unplugging the power cord & then plugging it back into
the machine to make sure it's getting the right connection.
if it still doesn't come on then the machine needs to be checked to
see what's wrong with it. cause if it's not the power cord it could be
the on off switch.
Oct 08, 2012 | Singer 1507
Mysony wega KDP-57WS655 press power button straight to standby flashing 10 times
Indicates a problem with the high voltage circuit. You could try unplugging the power cord, plug it back in and try again. If that doesn't work unplug the power cord again but leave unplugged for at least five hours and try again. Still doesn't work find a local repair shop that works on sony tvs and have them fix it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
When recording the sound is distorted
I saw your post, bmbkiones, and I'd like to help you with it! Make sure all connections on the back of the receiver and TV are hand-tight secure. If the problem is still happening, unplug the receiver's power cord from the outlet for at least ten seconds and then plug it back in. If that doesn't fix it, let me know what type of receiver you have. The model number can be found on the front panel in the bottom left corner. Also, what type of connection do you have from the receiver to the TV?
Hope that helps!
Jul 01, 2011 | Televison & Video
Pump motor stalled
Hi victor_orell,
The Pump stalled error it is often caused by the ink system has failed. To correct this error please follow the steps below.
1. Power drain. Please unplug the power cord at the back of the printer. Press and hold down the power key for 30 seconds then release the key and plug the power cord back in.
--> if this doesn't work please proceed to the next step.
2. Partial Reset. Please unplug the power cord at the back of the printer.Press and hold the # and 3 keys together and while holding them plug the power cord back in. Check if the problem is resolved.
If Not
3. Semifull reset: Unplug the power cord from the back of the printer again. Press and hold the # and 6 keys together and while holding them plug the power cord back in.
4. If you're still encountering the same error, please remove all the print cartridges (with the system powered up). Clean the copper contacts with the help of a lint free cloth then reinstalled them. Allow the printer to go through its normal sequence then go to the Setup, select tools, then clean print head.
Hope it helps.
Thank you for using FixYa.
May 02, 2011 | HP Photosmart C6180 All-In-One InkJet...
Failure Oxc05d0082
Hi eherndl,
The failure Oxc05d0082 description is a pump stalled error, it is often caused by the ink system has failed. To correct this error please follow the steps below.
If Not
Hope it helps.
May 01, 2011 | HP Photosmart C6180 All-In-One InkJet...
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
My toshiba laptop won't turn on!
Place the battery back in and the power cord. Follow the power cord all the way to the plug and verify nothing was unplugged by accident. (the box on the plug sometimes disconnects without the user knowing it) This could have caused your lack of power. Hope this helps.
May 09, 2009 | Computers & Internet
It keeps turning off
The audio output ICs or transistors are blown. Solid state elctronics are not very forgiving when they are shorted. it takes one tiny instantance and the componets will fry. sorry to be the bearer of bad news but you will need to have this unit serviced or replaced, And never ever work on any type of electronics with the power still on. Good Luck
Apr 07, 2007 | Yamaha HTR-5830 Receiver
Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder Logo
994 people viewed this question
Jerry Greenberg
Jerry Greenberg
