Question about Dell Latitude C600 Notebook
Touch pad is not working in my dell latituse 600
  • 3,940 Answers
If the touchpad is not working, then ensure that the touchpad is not disabled in the BIOS, in control panel ensure that is is not disabled there either. If the touchpad is not disabled in BIOS or Control Panel, then a palmrest would be required to fix the issue. On a system of that age, I'd just use a wireless mouse till I was ready to replace the system
Posted on Jul 04, 2009
How can i control the wandering cursor of my Sony Vaio Laptop?
Not sure which Sony you have. Does it have the old touch button in the center of the keyboard? I used to get many Old Dell 600 series and the problem was the touch button in the center was bad. With the customers permission I would cut the ribbon cable to that button and it would be fixed. It seems that a bad touch button would have the pointer wandering and conflict with the touch pad. If you only have a touch pad it will likely be that pad is bad. Change it out would be my suggestion. Good Luck!!!!!
Oct 21, 2014 | Computers & Internet
My touch pad not working probably .
Adel Heider,
You may want to first download the driver and install it into the system from the link below.
Inspiron 1545 Drivers Download Page
http://dell.to/14IpAJU
Erratic Pointer Movement
Here are some easy steps to take to determine the problem with a touch pad demonstrating erratic pointer movement:
  1. Get the latest driver from support.dell.com - Most problems can be corrected with a simple driver download. This should always be one of the first steps when diagnosing any touch pad problem.
  2. Check for hand and finger placement - The most common cause of random pointer movement is that the touch pad senses a finger or part of the hand near the surface of the device.
    • Have the customer attempt to use the touch pad normally but to pay attention to the location of his or her hands and fingers. Are any straying too close to the touch pad?
    • Adjust the Touch Sensitivity and TouchCheck settings in the Touch Pad Settings section of the Dell Touchpad Properties.
  3. Try an external mouse - Does this problem happen with an external mouse attached?
    • The Device Select section of the Dell Touchpad Properties has options to enable or disable the touch pad or external mouse. Try several combinations of these settings.
    • If the problems only occur when the touch pad is enabled and do not occur any time a mouse or other external device is used, then the issue is related to the touch pad.
  4. Check for mechanical problems - If the problem cannot be corrected by adjusting the settings mentioned above and only occurs with the touch pad enabled, then this could indicate a mechanical problem.
    • Press down on the palm rest on first the left side of the touch pad and then the right. See if the cursor starts moving on its own.
    • Run Dell 32-bit Diagnostics and try to recreate the problems there. If either of these situations occur, then replace the palm rest.
No Pointer Movement
No pointer movement from the touch pad (or track stick, if available) usually is the result of one of two things: The touch pad has been disabled in the driver interface, or the touch pad cable is damaged or disconnected. Follow the steps below to determine the problem.
  1. Connect an external mouse - In either situation, an external mouse should still function. If it does not, try booting into Safe Mode and testing both devices again.
  2. Enable the touch pad in the driver settings - Using the external mouse (or key strokes if no mouse is available), go into the Dell Touchpad Properties. Go to the Device Select section and enable the touch pad. If already enabled, get the latest driver from support.dell.com.
  3. Test the device in Dell 32-bit Diagnostics - To eliminate a potential software problem, run the Dell 32-bit Diagnostics and test the device here.
  4. Check for mechanical problems - As a last resort, press down on the palm rest where the touch pad connector is located on the system board. If the pointer reacts in some way, then the cable may just need to be reseated. Otherwise, replace the palm rest.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 07, 2013 | Dell Inspiron 1545 Notebook
I reinstalled vista 7 in my dell inspiron m5030 and the wireless internet and touch pad weren't working. I downloaded and installed all the drivers and the wireless internet worked but still the touch...
Try connecting an external mouse via USB port. If that works you probably need to have the palm rest (top plastic piece that contains the touch-pad and buttons) replaced.
Sep 01, 2011 | Dell Inspiron M5030 Laptop
I have a dell vostro A860 laptop.not working to Touchpad. How to Fix Touchpad Not Working in Laptop
What you can initially do is to update the driver.
  1. Press on the windows key + R. A run box will appear.
  2. Type devmgmt.msc then click on ok. The device manage will appear.
  1. Click on the plus sign besides mice and other pointing devices.
  2. Right click on the item that will be pertaining to your touch pad.
  3. Choose update driver and let the internet work for you.
If this does not work, you will need to totally reinstall the driver.
  1. On the same screen (device manager) right click on the touch pad driver again, the choose uninstall.
  2. follow the prompts for uninstallation. You might wanna uninstall any mouse related drivers as well (these application can also cause conflicts thus causing your touch pad not to work)
  3. download the touch pad driver available from the link I provided below.
  4. follow the prompts for installation.
  5. restart
Dell Vostro Driver list (click here to view all available drivers for your portable system)
Dell Vostro Touch Pad Driver (click here to download the touch pad driver)
It this does not work, you will need to call Dell Technical Support to have the laptop serviced. That is if the portable still has warranty. If not, then you will need to buy a USB mouse as a replacement.
for additional information visit Dell support website: support.dell.com
Jul 18, 2011 | Dell Vostro A860 Notebook
Dell XPS M1530 Vista originally installed - Fresh installed Win7 and now touch pad does not work - the right button works, and sometimes the left, but the touch pad does not. I've install the latest...
If you've reinstalled the drivers for the touchpad, the issue is likely the hardware- if in warranty, contact Dell tech support- if not, you may need to purchase the palmrest assembly and consult support.dell.com for the install instructions
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 24, 2010 | Dell Inspiron 1545 Notebook
How to use touch pad dell latitude D610
The touch pad on a Dell Latitude D610 works much the same as with other laptops. You can move your finger around the pad to simulate the movement of a mouse, and it will cause the pointer to move across the screen. You can also tap on the touch pad (gently) to "click" on a file, folder, or other item. The touch pad on a D610 doesn't have a hardware switch like some other laptops do so that you can turn it on or off -- it's just always on.
Aug 08, 2010 | Dell Latitude D610 Notebook
Touch pad not working on dell 1545
When touch pad does not work it is because of service not running or corrupt drivers. Service is most likely dell event service. If you go to dells site and search for touch pad not working it will give you detailed instructions on how to fix. i had same issue with my sony laptop where it just stopped working and also my FN button was not working. Hope this helps.
May 07, 2010 | Dell Inspiron 1545 Notebook
The left key on my dell touchpad is not working
that part of the touch pad is not working anymore, its faulty and you need to replace the whole touch pad.
I don't know why this is mostly common with Dell. My friend has a Dell inspirion 1501 and the touch pad has exactly the same problem as yours.
I would advice you get a USB mouse to keep you going pending the time you get the touch pad fixed.
I wish you the best of luck.
Jan 06, 2010 | Dell F3534 Touchpad
Laptop touch pad mouse does'nt work while charging
my toch pad dont work when my laptop is charging i have inspiron 1525
Feb 26, 2009 | Dell F3534 Touchpad
Dell inspiron I6400 touch pad is not working
Unless there is not a hardware switch and the only manufacturer that I know of that did that was Compaq/HP about 5 or so years ago. Typically there are no drivers to be installed for a mouse (touch pad) as a generic set is in the driver library of the operating system. 9 times out of 10 it is a hardware failure. With that being said, if it has warranty send it in, if it does not, (although it may just be a loose connection or the touch pad itself) most repair shops are going to run anywhere from 150 - 300 dollars just to crack it open. Best option is to get a small USB mouse, unless you just really want the touch pad.
Nov 17, 2008 | Dell Inspiron 6400 Notebook
Dell Latitude C600 Notebook Logo
339 people viewed this question
Alun Cox
