AcerView 56C (White) 15 in.CRT Conventional Monitor Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi: My acer56c is eight years old and humms while turned on as well as getting the horizontally linear blue occasional flash across screen.The colors when turned on are not 'initially' accurate(Orange vista logo may be light blue). Is it wise connecting this to a brand new DELL ? BMW
johndoe1999
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 86 Answers
  • Posted on Aug 11, 2009
johndoe1999
Expert
Level 2:
Cheetah:
Answers
86
Questions
0
Helped
13162
Points
103
If its a CRT monitor then you wont have a problem, the all get decrepid and loose color flicker then eventualy die.
i say use it till it dies then get a new one or get a new one befor it dose damage to your eyes, a nice TFT screen will do.
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
2helpful
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Sony KV-27S10
is it vertical problem or retrace lines can you tell
Heavy white lines accross the screen
change the ram and viedo card agian
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
2answers
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
