Question about Garden
Won't stay running like it is not getting gas. just bought it used. It has sat in a shed for a couple of years. It is getting spark and will start briefly when I squirt some gas into the spark plug hole.
  • etlong72 Jul 04, 2009
    Thanks for the input. I disassembled the carb and cleaned it with carb cleaner. I also took the gas tank off emptied and filled with fresh gas. Put it all back together and it started on about the 4th pull. Pretty good considering I talked them down $100 because it wouldn't stay running when I went to buy it.
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
    Scholar:
  • 59 Answers
Ahh easy, carb lines are either blocked, and (or) old (cracks) thus giving you a Vacuum leak, (gently) pull them out and see if (filter) is also "clogged", if it is either replace, or attach a "clean" piece of tubing and again (gently) blow some air through it, put back and place the right Mixture of pre-mix in it, let me know if this does the trick,god bless
1993 5.7L. Why is it difficult to start and keep running?
Why was it left to sit? That is the first question to find out. Check compression, First thing.
Jul 30, 2015 | Chevrolet Cars & Trucks
Honda Harmony II HRR216 won't start
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
May 18, 2013 | Garden
Lawn mower won't start
Take Breather element off,and try to start it Then or if it starts that way cut it off and replace the breather and if it doesn't start You May need to change spark plug also, As if You have flooded it, Gasoline will kill a spark plug
Mar 27, 2013 | Garden
Generator Won't start
Gap the plug at .030 What is most likely the main problem is whatever gas sat in the carb. Even with fresh gas there will be some old gas still in the float bowl. You may be able to drain the bowl and be OK but I have a feeling that the carb will need to come off and be disassembled and cleaned properly. You can try spraying carb cleaner (I dislike starting fluid as it is too volatile and carb cleaner does just as well in this instance) into the carb/intake. Remove the air filter, open the choke, and spray the carb cleaner in through that way if possible. You can actually keep an engine running by spraying with short bursts. Even by just spraying once you should be able to get the engine to start. If it does start but then will not stay running without spraying more into the engine then it is a carb problem.
Aug 24, 2012 | Coleman Powermate 6250 10hp Generator
83 ford mustang sat for two years now won't start
The fuel system is most likely gummed up from bad gasoline, flush the entire system, replace the fuel pump and the filter as well. Add a can of CHEMTOOL to the gas tank to help dissolve the varnish.
Jul 19, 2012 | Ford Mustang Cars & Trucks
My mountaineer won't start. It sat for a little over a year because of transmission issues. When I finally got a trans for it, it wouldn't start. I replaced all spark plugs and replaced the...
If the engine is turning, but slow, she may need the battery terminals cleaned, if it has sat for over a year, yes, it may need a new battery. If the engine is turning over and she is not cranking up. Standard rules apply... does she have fuel? does she have spark, does she have compression? First thing is easy, get a can of starting fluid and give her a spray in the air filter area during cranking, if she pops off you have spark, which means no fuel. If it does not try to hit, that means no spark and more trouble shooting will need to be done. If it starts on starting fluid, you may have a bad fuel pump. AS gas turns to gunk as it dries up. And that may have gummed up the pump and filter. Hope this helps FixYa up.
Sep 12, 2011 | 2003 Mercury Mountaineer
I bought a Troy built tiller. used once two years ago. then it has been sitting in a shed. It had old gas in it. I drained gas tank. I am getting a spark. when I pour gas in air breather, it starts, but...
I have had good luck using an engine starting fuel, sprayed into the air cleaner/intake. Any auto repair store will carry this product. CAUTION, HIGHLE FLAMMABLE!!!!!!! Many mechanics frown on using starting fluids, but I have a bad shoulder & that is what I do on the 3rd pull.
Louie Almond
Mar 27, 2011 | Troy-Bilt Pro-Line 160cc FRT Tiller
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
SMALL ENGINE PROBLEM
Carb will need to removed and thouroughly cleaned.
Also you can file or clean coil where the contacts rub on flywheel.
Change your spark plug as well.
May 13, 2009 | Garden
1995 AUDI 90 CS - Hard to start... spark & fuel OK
Have you tried replacing the starter? I know starters can go bad if the car is not started or run for a long time.
I am getting the same car, with the same issue.. it sat for 2 yrs and won't start.
My mechanic told me it is probably a starter.
Mar 16, 2009 | 1995 Audi 90
Garden Logo
163 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
