Question about Garmin Forerunner 301
My garmin 301 won't charge anymore. I've determined that its not the charger so I'm thinking its the connector pins because I use to have to wriggle it around a few minutes to get to show the charging sign, now it won't charge at all. Greg
SOURCE: iQue 3600 power connector specification needed
see "http://pinouts.ru/PDA/palm_m125_pinout.shtml
Posted on May 01, 2009
  • 4090 Answers
SOURCE: Charging a garmin nuvi 255w
From dead flat it takes about 9-10 hours
do not leave on charger for more than that otherwise you will overheat and burn it out.
After each use recharge for about 3-4 hours depending on whether the unit has been used for that lengthyof time
Posted on Jun 30, 2009
SOURCE: Garmin 205W doesn't work while charging in car
I have a 205w and have been very frustrated with this same issue, but I just so happened to find the following fix on another site today and it works great.
Follow these steps:
Turn on the unit on battery, press the battery icon and hold for about ten seconds, and the unit will switch to the diagnostic mode. Now plug in the USB cable and it will give you a loud bleep. Exit the diagnostic mode and it will operate normally while charging. This was handy to enter favorites while it was charging.
Posted on Jul 20, 2009
SOURCE: won't turn on or charge
Press Mode (bottom left side button) and Reset (left front button) simultaneously, let go, then press On (top left side button).
Posted on Aug 06, 2009
SOURCE: Garmin Nuvi 250 stuck in mass storage mode
Make sure you have the rite charger. Garmin will only work with a garmin charger. You may have accidently picked up a blackberry charger or something. Hope this helps
Posted on May 21, 2010
Why want my tablet charge Where do I return my tablet it will not charge anymore
Most common cause of this is faulty charger, the metal connector at end of wire won't connect properly to device charging port.
Test it by putting plug back in Tablet charger port and very very gently wiggle it around very slowly, see if the charging light comes on or flickers. They usually make a beeping noise when successfully charging or the screen lights up. If you get intermittent charging then it's the charger and time to get a new one. Very common, most are USB connectors or small pin types.
If it's still under warranty then send it back to the place you bought it before you try testing it.
Oct 07, 2016 | Tablets & eReaders
My rino won't charge
Two things occur to me: possible damage to socket where charger connects to unit------or no voltage from charge source to the battery
A lot of the connectors where the unit connects to power are easily damaged.
Nov 03, 2012 | Garmin Rino 530 GPS Receiver
Why won't my Garmin Nuvi 780 charge?
A couple part answer here. The USB pin out for the Garmin is strange. If it goes into PC mode, then the cable is got the wrong pin out for the unit. Try different cables until one works.
If you can get a full charge on the unit and the battery does not provide at least an hour + of battery use, then the battery needs to be replaced. Amazon sells replacement battery kits with instructions. You just have to make sure you order the right one.
Sep 18, 2017 | Garmin nuvi 780 GPS
My nokia E5 won't charge, I've tried another charger but still nothing
can you see the pin in the charger socket? these can get bent, other wise looks like your charge socket has come free, from the board
May 16, 2012 | Nokia E5 Cell Phone
Philips 707/05 Portable DVD Player charging issue.
Just go out and get a new charger to replace the one with defective wire/plug.
Aug 31, 2017 | Philips Vacuums
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
When I plug the gps into the charger a computer picture shows up and I can't get it on any other screen. What's the matter?
Did you recently purchase that charger?
This usually happens when the charger is not compatible with the unit. or you could be using a non-Garmin charger. There are some "store-brand" chargers that work well, and some do not. Store brand Charger are made to be Universal. To fit multiple devices and maximize profits. You want a Garmin Specific Charger, and here is the logic why...
The reason behind it:
1. The Garmin USB Cable that you connect to your computer has a special 4-pin configuration telling the GPS that is is connected to a computer. This is the configuration most "generic" chargers use to maximize device compatibility.
2. The Garmin Car Charger has a different pin configuration with 2 less pins, giving it only positive ( + ) and Negative ( - ) to charge the GPS.
When the GPS receives the 4 pin, which is also found in a "Motorola" Cell phone charger, it will automatically sense that it is connected to a computer.
Long winded, but I wanted to explain why. Simple fix, Just go get a new charger and make sure it's Garmin compatible.
Jan 04, 2011 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 750 car cradle/charger does not charge the unit. USB charger works, so not the battery. Replaced the cigarette lighter jack and still does not work. Problem must be in the dash mount cradle...
Hi tbrick
if you dont have the original charger, the 750 take a special car charger because of the traffic feature...it has a flat end about 3/4" to 1" long that fits in the cradle, but you can use a garmin usb charger, you just wont be able to use the traffic feature.
if thats a little confusing ( i tend to do that) i try and explain it another way.
if you think you need or want one of those chargers, just post back to me.
bill
Nov 01, 2010 | Garmin nuvi 750 GPS Receiver
Nuvi car charger problem
the connector is defective in the GPS, this is a common problem, it must go back to Garmin dfor repair
May 28, 2010 | Garmin nuvi 260W GPS Receiver
Garmin won't charge or turn on.
Hello :
How old is your battery ? I think that the battery life is ended [ can't be recharged anymore ] . Just replace it and problem will be solved .
please rate !
Apr 14, 2010 | Garmin nuvi 205 GPS Receiver
Garmin Forerunner 301 Logo
450 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
