Question about Mitsubishi WD-62526 Projection TV
Whats the best replaceable lamp for my wd-62526 tv?
  • 261 Answers
It would be a philips lamp!!! They're the best in the market, discountdashmerchantdotcom :) take a look around and you'll see :P
Posted on Jul 03, 2009
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
Mitsubishi wd-62526 error code 45
It's a lamp fan failure part no. 299P296010, its available at ebay and tvserviceparts.
Oct 07, 2011 | Mitsubishi WD-62526 Projection TV
Buy a mitsubishi tv lamp
You can get replacement lamp with housing assembly from www.tvrepairworld.com
Sep 25, 2011 | Mitsubishi WD-62526 Projection TV
How do you know if your lamp is out. there is still light on in the back of the tv
An LED indicator on the front panel of your TV will blink even you have light in the back panel of your TV this LED indicator will remind you if the lamp must be replace because DLP projection has a lamp hour meter the lamp time for this DLP 6000 to 8000 hours.
Sep 23, 2011 | Mitsubishi WD-62526 Projection TV
I have a Mitsubishi tv model wd 62526 it makes a noise when I change channels and also when images change. Someone told me it could be the color wheel, also I do not have bright colors, I changed the...
This is an LCD projection tv- there is no color wheel, have your tv serviced- cleaned, hopefully you dont have optical block issues. contact a service shop.
Jan 14, 2011 | Mitsubishi WD-62526 Projection TV
My mitsubishi wd-62526 red light is on for lamp and there is no picture
this indicates a bad lamp. your owners manual has instructions for replacing. there will be a lamp door on the back or behind the speaker grille. if the lamp is shattered or bulged/white it is bad. if the lamp looks good, you may have bad capacitors on your power supply.
May 26, 2010 | Mitsubishi WD-62526 Projection TV
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Mitsubishi WD-62526
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62526 Projection TV Logo
124 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
