Question about Sony Cyber-shot DSC-W50 Digital Camera
Problem Hi!Please answer to my question. When im opening sony digitel camera it showsblack screen and is written memory stick and after its working as usually works. But how i remember before never was written at first memory stick. I think maybe it shows that memory stick is full? Thank you for answer.Best regards suzan
  • maireadgal May 04, 2008
    When I turn on my sony cyber-shot camera the screen is black for taking photos. I think te problem is with the lens because when I look back over previous pictures they appear perfectly
  • 74 Answers
Try two things re formatting the memory card in your pc if this fails switch on camera take the end of the lense and gently twist and pull the lense you may here it click be gentle do not force it then switch off and on again this may solve your problem
Posted on Oct 17, 2008
How do i resolve the C:13:01 error on a SONY DSC-W150, "error formatting memory stick" appears on the screen"?
how do you formate memory stick if the camera woke work at all. It keeps saying reinsert memory stick . Must be a w150 problem cause that's what mine is doing too! :(
Apr 21, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Reinsert memory stick --- I have removed battery and memory stick with no result. Help
Sony says:
Article ID : 101488 (modified 10/29/2009 03:18:00) Question: A warning message appears on the LCD screen when a Memory Stick is inserted into the camera. Answer: The following could be possible causes for the error message to appear:
  1. Verify that the Memory Stick is inserted correctly.
  2. The inserted Memory Stick cannot be used in the camera. Refer to the related link below for compatible Memory Stick.
  3. The Memory Stick is damaged.
  4. The terminal section of the Memory Stick is dirty.
http://www.sony.com.ph/support/faq/101488/product/dsc-w190/modelfirst
Jan 02, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Vidoe option on camera used to work, but now: 640(fine) is not available
Hi
I think to work on 640 fine you need a much higher memory stick, I use a 2gb in mine and it is fine (that is when the camera works) .You get 24 minutes or more on the 2gb stick and that is at 640 fine.
Jul 10, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Transfer pics from internal memory to memory stick
look im sorry to be so mean. but come on dude... it has a "USB PORT"! you take the memory card out of the camera first, then you plug it(the camera) into the computer and turn it on and it will automatically show up as "Sony MemoryStick" in "my computer" then navigate to the obvious file containing directory. copy and paste them to where you please...
keep in mind you have to be set to "Normal" mode for it to work or you may have trouble. hit the menu button to explore the 3 option menu. you cant get lost.
Jun 24, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony camera
hi there
those pics that youve saved are still there in the memory stick. the camera though, im no so sure if its retreiveable. even if you dried it, you said that it still wont work. what you can do for your camera is bring it to the service center and have it looked. your memory stick will work though if you cn\onnect it to a card reader/writer and have those pics saved to a media like cd or save it to your computer.
hope this helps.
Feb 04, 2008 | Sony Cybershot S650 Digital Camera
Sony cyber shot DSC F717
Hi
Switch your camera to Setup on the control **** located on the top.
Take out the memory stick and press the reset button located inside the battery compartment.
Now switch on the camera and insert the memory stick.
If you do not get the error go to the little toolbox on the menu. Select the format option and proceed through the warning messages. Remeber you will loose all data on the memory stick.
Things should now work. If not some simple thing that sound bezare but has worked for me is pushing the memory stick in and out before the camera displays the error. Do this several times until the camera actually reads the stick and them format the stick first chance you get.
Good luck.
Oct 22, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Reinsert Memory Stick Message
i have sony cyber shot keeps saying reinsert memory stick cant veiw any pictures taken nor download cant take any new pictures have i lost all my pictures how can i get them back
May 03, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
44 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
