Question about HP Officejet 7210 All-In-One InkJet Printer
HP Officejet 7210 "hangs" when starting a job. It gets through initializing when powered up, but after doing the # 6 powerup reset, it has a message "Aligning Cartridges-Please Wait" but does not do anything. What should I try next?
I had this problem. I found an obstruction under the print cartridges. A small plastic cover had come loose from the printer somewher. on removal the printer worked fine
Posted on Feb 11, 2011
  • 34 Answers
You should have a program installed on your computer called HP Product Assistant. Try running this program to determine the problem.
Also, make sure all the ink cartridges are fully seated.
You might also try unplugging the printers power cord, let it sit for a couple minutes, then plug it back in.
Posted on Jul 03, 2009
HP 7210 Officejt is not printing
Are you able to make copy from printer or print test page ?
If you are not able to make copy from printer or print self test page
Check if the cartridges are not empty.
If they have ink, follow the steps below
1. Disconnect the power cable from back of printer
2. While holding the # and 6 button, connect the power cord to printer.
3. It will print the alignment sheet and you will have to re-align the printer and try to print/copy
*Note this is Semifull reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Or are you not able to print from PC ?
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 23, 2010 | HP Officejet 7210 All-In-One InkJet...
My HP officejet all-in-one printer has been displaying the message: Remove and check right cartridge. I have checked it and cannot get it to print, scan or remove that message.
remove all the ink cartridges, and then unplug the power cord from the back of the printer.
Now, hold down # and number 6 button together, and while holding them down, plug the power back in.
release the hold after about 30 seconds, or the display saying nvram reset .. something like that .. If the printer turns off , then you will have to turn it ON again .. and then insert the ink cartridges ,
this will reset the machine.. and should resolve the issue. Also check if yu have any old cartridge and first insert that and see. if no error on inserting the old cartridge and that if it come by inserting the new on, then it could be the cartridge problem. Will have to try with new ink cartridge.
Sep 07, 2010 | HP Officejet 7210 All-In-One InkJet...
HP officejet 7210 error message color ink refill
this error is recomded for the printer becouse printer will count the print out
Apr 12, 2010 | HP Officejet 7210 All-In-One InkJet...
How do I reset the regionalisation? I have UK 7210 with US cartridegs whch it won't recognise.Someone, somewhere must have noted the HP tech instructions for this process? Can't be rocket science; can it?
hi to reconfigure the regional setting we need to do a reset on the printer which will reset the printer to its factory settings to start the reset ensure that the printer is powered on and disconnected from the computer now press the # and the no 6 button on the printer together and then remove the power cord from the back of printer while pressing the # and 6 after 10 sec reinsert the power cord and relese the buttons it will start a semiful nvm reset after 2 min it will ask you the language and then region select the region and your printer will be reconfigured all the best
Jul 19, 2009 | HP Officejet 7210 All-In-One InkJet...
Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Jun 20, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
I need a power cord for my HP officejet all in one 7210 series
You can buy them from HP by calling 1-800-227-8164, Monday-Friday, 8:30am to 6:00pm EST. You only need to do this if you need the adapter. If it is only the power cord running from your electrical outlet to the adapter that you need, you can get that at any local computer shop for a couple of bucks.
Jun 07, 2009 | HP Officejet 7210 All-In-One InkJet...
HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
  1. Remove the document feeder tray from the product by gently pulling it.
  2. Lift the cover of the automatic document feeder by pulling it outward.
  3. Gently clean the rollers with a very damp cloth ansd a dab of dish detergent.
  4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
To clear the "scanner error" message do a
Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
If a partial reset did not work do the following: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, unit may need service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 11, 2009 | HP 7210 OfficeJet All-In-One Printer
Carriage jam
Try this (it may not work) -
Perform a Semi-full Reset on the unit by following the steps below:
1. Make sure that the unit is on, and disconnect the power cord from the back of the unit.
2. On the unit keypad press the # and the 6 keys simultaneously and hold both keys down while plugging in the power cord.
3. The Semi-full Reset message will appear on the unit display.
Wait until the unit initialization process is complete. The unit will have recovered its original settings.
I've had this error before and had no obvious fault with the carriage (it moved freely and the encoder strip was in place) i managed to clear the error by stripping the printer down and cleaning around the service station area
May 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP 7210 OfficeJet All-in-One errors
My Hp came with a setup CD that has very specific (required) drivers. Truthfully, if you machine is using the wrong drivers for the selected printer, it will interpret the bi-directional communication with the printer wrong - as evidenced by the false "Paper Jam" message.
Here's a path to HP's drivers for the 72000 series printer and Mac OS.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=219&lc=en&cc=us&lang=en&dlc=en&product=391153
Dec 30, 2007 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
204 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
