Question about Garmin StreetPilot 2610 GPS Receiver
Garmin 2610 'ok' doesn't work
We have the latest software. Have tried repeatedly to calibrate but calibration always comes back with 'failed'. Also, if I got to the "Find" and try to scroll down using the side bar, it just goes to the "entertainment" list. So it is basically unusable now.
  • honeypi Dec 26, 2007
    It helped a little, but the calibration still fails and also it doesn't respond when I touch the top right corner of the screen where the X is.
    We noticed that when we are at the 'calibration' screen, there is a vertical and horizontal line, and when you move your finger left or right the vertical line stops about 1/2 inch before the edge and cannot go any further. But when you move your finger top to bottom, the horizontal line can go all the way to the top or bottom edge. Does this help?
    Thanks for the suggestion.
  • hits-man Apr 13, 2009
    Exzact same problem will not calabrate on the horizonal
  • 4 Answers
Try brush around the edges of screen...press the edges and work out dirt.... Let us know. See other posts...Same problem with screen touch system not responding.
Posted on Dec 26, 2007
When trying to calibrate my incline, I'm told that the calibration process failed.
The software is corrupt, try to replace the ROM or EPROM from Console, or try if you can get the software from manufacturer, or to Replace the completely, Console in extreme case.
cuadra2016@yandex.com
cell+whatsApp:+50588611441
Oct 26, 2017 | Exercise & Fitness
Why won't Dell s510 pen calibrate?
Needs an updated Driver. Update from the Device Manager on the Control Panel, or it is just a bad pen, take it back if it is bad
Sep 10, 2015 | Dell Computers & Internet
My canon lide 700f will not calibrate to scan a 35mm film
For those having the "Executes calibration. Pull out the film and place the Film Adapter Unit at Frame 1." issue and cannot calibrate the scanner for NEGATIVE FILM, it took me ages to figure out how to solve it.
Solution: calibrate the frame, WITHOUT any film, adapter plug and placed in frame 1, and proceed to do the calibration WITH THE SCANNER COVER OPEN.
Before I tried everyhing, install new drivers for Windows 8.1, MP Navigator, and nothing happen. Now it works like the first day. Hope it helps! it certainly helped me.
Jan 29, 2013 | Canon CanoScan LiDE 700F
Wtw 4950 wont start
you need to get into diagnostic mode and check the error codes. This washer will give you couple of error codes but the first one is the latest. To check error codes
How to Read Vertical Modular Washer VMW Error Code Display
Calibrate/reset error
How to Calibrate Top Load Washer
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
Nov 22, 2017 | Whirlpool WTW4950XW Washer
HOW DO I RE CALIBRATE THE SCREEN?
Take note that calibrating the screen does not just work the moment you try it, you need to try it repeatedly till you get it right. This is how to calibrate your nuvi:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen for about 30 seconds until the calibration screen comes appears (white screen with touch dot),
  4. Follow the on screen instructions.
It is an easy fix. The solution above will help you out on that. Another solution is for you to remove the battery and fix it in back. That should also help.
Jan 07, 2011 | Garmin nuvi 1300 Car GPS Receiver
Calibration wizard.you have to calibrate the touch screen
calibration wizard. you have to calibrate the touch-screen mobile model No: JC 777s
Jun 13, 2009 | Handmark Software MobileLists (950142) for...
Calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Jun 03, 2009 | Bowflex Treadclimber
Scan coming in all black with DocketPort 485
The first thing that you should try is to calibrate the scanner. If you don't have the calibration paper you can use a blank white 8 1/2 x 11 sheet. This should clear it up. If it fails calibration after repeated tries you most likely have broken the lens or the image sensor is no longer working. If that is the case then there isn't much you can do i would suggest contacting the manufacturer and hoping that unit is still in warranty.
Nov 19, 2008 | Ambir Technology DocketPort 485
Print is right when preview is very magenta (like 40 pts magenta)
This sounds like a calibration problem. The first thing I would try is to un-install the driver, download the latest drivers from the manufacturer's website then reinstall the new software.
I'm not familiar with the drivers of this printer but look to see if there is a printer/monitor calibration area try the settings there.
The other obvious place to look in is the software you are printing from. Try printer/Monitor calibration in the help menu
Jan 24, 2008 | Epson Stylus 2200 InkJet Photo Printer
Garmin StreetPilot 2610 GPS Receiver Logo
308 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
