Question about Bose 3 2 1 GSX System
Bose Lifestyle 48 System Set to Wrong Input (Black screen)
When I press the system or settings button on my Bose Lifestyle 48 remote and change the input I just get a black screen. I tried to switch to the DVD in put by pressing "DVD" but I'm hooked up to a HDTV so it can hear the sound but not the video input...The problem is that I accidentally changed the video input on the Bose system when I tried hooking my xbox up to the bose. I have a potential solution but I need someone's help....
Can someone who's Bose is working give me instructions on how to change the TV input? I know the system is working its just on a different input..So when i press "System", it says see tv but goes to a black screen. I can still change the settings I just can't see what I'm pressing. SO if one of you could tell me what buttons to press in order to change the TV in put, I could try fixing the problem on my bose...Please help..
SOURCE: Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Posted on Feb 24, 2009
SOURCE: open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Posted on Apr 22, 2009
cjackHD
  • 71 Answers
SOURCE: Bose Lifestyle 48 System play's dvd in black & white only
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
Posted on May 31, 2009
smarthome2
  • 1114 Answers
SOURCE: bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Posted on Jul 26, 2009
SOURCE: audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Posted on Dec 28, 2009
I have an optical cord plugged into my bose system but when i change it to aux it doesnt work
Using the remote control, and the on-screen settings menu, you must set OPTICAL as your AUX input. After this is done, Your Bose Lifestyle system will recognize the signal on the optical input.
Oct 19, 2009 | Bose Lifestyle 38 System
Tip
Bose LifeStyle 48 Video Mode
Bose LifeStyle 48 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Reset Bose LifeStyle 48 VChip Password
on May 02, 2010 | Televison & Video
Tip
I hope that helps.
on May 02, 2010 | Bose Lifestyle 48 System
Remote control codes for bose
The DirectTV Website has a page to find remote control codes, and it lists lists four different remote controls to choose from. Find it here:
http://www.directv.com/DTVAPP/global/contentPage.jsp?assetId=3580003&
I fired "Bose Lifestyle" into the first choice and it gave me the numbers
31229
here are the instructions from that page:
Setup Instructions
  • Set the "Mode Switch" to AV 2.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • I hope that helped.
    Sep 19, 2009 | Bose Lifestyle 48 System
    Bose lifestyle 48 dvd black and white only
    Jul 26, 2009 | Bose Lifestyle 48 System
    Change Bose Lifestyle House Code - doesn't work like in the book
    The solution to this is that the operating manual say you should hold down the wrong button!
    It says hold down the button "store" when then button you should hold down is "enter".
    Jul 07, 2009 | Bose Lifestyle 48 System
    Have Lifestyle Bose 48 installed by Bose technican. All has been well. I was attempting to watch a movie on Demand from the Cable and it was doing tracking blurring... Must have hit the wrong button on the...
    Does the Bose unit have selections for more than one signal source (video 1, video2, antenna 1, antenna 2, dvd, etc.)? If so, test to be sure that it is set to the correct input. Also, if the television has these options check it as well. Good luck and let me know how you make out.
    Jul 05, 2009 | Bose Lifestyle 48 System
    Bose Lifestyle 48 not responding to remote or manual functions
    I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
    Apr 21, 2009 | Bose Lifestyle 48 System
    Bose Remote Control RTC1T-27
    I called Firedog and paid them $80 to come out and fix it.
    Jan 04, 2009 | Bose Lifestyle 20 System
    Lifestyle 48 locked up
    Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
    I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
    Jan 26, 2008 | Bose Lifestyle 48 System
    Bose 3 2 1 GSX System Logo
    140 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
