Question about Yamaha 12V Air Pump
Loss of speed
Jet ski only runs at 12 mph No problems starting or reversing. changed impeller, spark plugs, and air filter still having the same issue.
  • griffin3406 Jul 08, 2009
    2003 Yamaha FX140
    The engine doesn't rev it just doesn't want to go any faster than 24 mph. We changed the gas also and that's when it went from 12 mph to 24 mph but hasn't improved speed since. Starts great and runs fine.
  • thomas foster
    thomas foster May 11, 2010
    what kind of ski and does the engine rev like it wants to go but doesnt?
    President:
  • 1,978 Answers
If you got to this page and look up your model it will tell you the standard settings for your high and low speed jets. Resetting back to stock settings may perk your boat back up.
http://www.shopsbt.com/forum/showthread.php?t=13981
Posted on Sep 09, 2010
  • 30 Answers
Try having the carbs cleaned.
Posted on Sep 21, 2009
Hi, so i have a derbi senda baja 125 wich was running great until i decided to change my air filter to a conic one. Ive made that change and now it loses power on high revs. Can u help me?
Hi, Martim tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. Here is how and where you compensate trouble:
1. Your air/fuel mixture screw manages your idle.
2.. Your slow speed jet manages 0-1/4 throttle opening.
3. Your jet needle c-clip position manages 1/4-3/4 throttle opening.
4. Your main jet manages 3/4-wide open throttle.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues. Good luck and have nice a day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 31, 2015 | Derbi Senda Baja 125 SM Motorcycles
What can I do to fix my 1988 Ford Bronco xlt with a 351 engine that has rough idle and loss of power when in drive?
Fuel filter. Low fuel no power. Catalytic converter. no air out, no air in. loss of power.
Jan 25, 2015 | 1988 Ford Bronco
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Increase speed
Hi, Anonymous if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" you're not getting enough fuel.
1. Close to 1/8 throttle is managed by the air screw and pilot/slow jet.
2. 1/8 to 1/4 throttle is managed by the air-screw, pilot/slow jet, and throttle slide.
3. 1/4 to 1/2 throttle is managed by the throttle slide and jet needle.
4. 1/2 to 3/4 throttle is managed by the jet needle, needle jet, main jet, and air jet.
5. 3/4 to wide open throttle is managed by the main jet and air jet.
6. Wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, the engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Wave100 speed test video
GPS Honda Wave 125 with 140kph topspeed
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda Wave 110i User Manual
Sep 05, 2013 | 2005 Honda NF 100 Wave
1995 zx-6r ninja won't go over 100 mph
Hi, Anonymous if you have changed your engine size, compression ratio, fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve, and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" you're not getting enough fuel.
6. A wide open throttle is managed by the main jet.
For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
http://www.kawasakimotorcycle.org/forum/kawasaki-streetbikes-sportbikes/88108-zx-6-wont-go-above-100-mph.html
My bike won go faster than 100mph ZX Forums
Carburator Theory and Tuning
Kawasaki 1985 ZX600 Service And Repair Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Apr 01, 2013 | 1995 kawasaki ZX-6R Ninja
My RPM's are norman and even higher but I'm down about 10 mph.
This is a shot in the dark BUT check to see if there is a wear ring that would sit around the outside of the impeller.Its inside the pump but would be right where the impeller spins.Jet skis have them and I thought yours may also.Hope this helps
Jul 12, 2010 | Boating
My Polaris freedom(jet ski) starts and runs good
Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer. I know all these are expensive but if your going to be a polaris tech you will always need them. Troubleshooting (1) check compression. Look at your Clymer manual for specific psi.all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine
times out of ten.Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace and replace all fuel filters. Polaris has a gravity filter under seat, clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a C.D.ignition. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive polaris, if the problem is still there then there is further steps to take. If your polaris is fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your polaris. Troubleshooting tips and teaches you how your polaris works. If its carburetor then you should clean carburetors. Inside the carbs is another filter that needs to be cleaned. Its not difficult you just make sure you put everything back in proper order. take pictures if you need to.
Sep 18, 2009 | Boating
2008 Yamaha vx deluxe will only run about 30 mph
if the motor is reaching full revs look at the jet assemby for fouling or prop damage. If it is not reaching full revs get authorised mechanic to fix it, it will be cheaper in the long run.
Aug 31, 2009 | Sport & Outdoor - Others
Jet ski will not run at full throttle
Check for holes in the diaphram the pulses the needle and seat in the carb.
Jul 23, 2009 | Sport & Outdoor - Others
Yamaha 12V Air Pump Logo
361 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
