Need to know what Carrier air handler will work with a 24ana760a003 Infinity? Please help
  • 614 Answers
I am a Carrier Dealer. Here is your info 1 Model FE4a or FE5a The 5 is upflow only where the 4 is multi positional. F is fan coil E is Infinity A is series N is the voltage. By the way I have the Infinity series in my home it is quiet and very low cost on power bills if it is set up right. Most service techs dont like to work on them . They are very high tech. You will like it Rus
Posted on Jul 05, 2009
Carrier air handler/furnace won't turn on
from what your saying the motor is hot to touch if that is the case the motor is bad need to be replaced.
Nov 08, 2014 | Heating & Cooling
Carrier 58MVC100 furnace no power. Tree fell on main power line and after power restored noting going on with furnace/air handler. LED is not lit. 3amp fuse appears to be good and there is a sulphur smell...
Possible that when power got restored you furnace might have gotten surged. replace fuse any way to be sure. Check break box for trip circuit. Call a tech from there man.
Aug 08, 2013 | Carrier Infinity 58mvc080 Gas Furnace 80k...
My air handler sprung a leak and needs to be replaced. Would it be a bad idea to use a Lennox CBX32MV-048 variable speed air handler or is it better to get a carrier air handler?
They are expensive to buy, and to replace it as well. I would not to expensive. Any air handler, just not a variable speed.
Jul 06, 2011 | Heating & Cooling
Carrier infinity a/c thermostat screens are blank - no power
There is a fuse in the control panel, and depending how they wired it may be a inline fuse. also there is a fuse in the airhandler also they both should be a 5 amp auto fuse.
Jul 18, 2010 | Heating & Cooling
Need to connect a universal fan relay with a transformer
I hope you are good at electric becaue you are biting off a chunk here...
Check out these diagrams they are for Honeywell but all the fan centers are pretty much universal...
http://customer.honeywell.com/techlit/pdf/60-0000s/60-2023.pdf
or this one...
http://customer.honeywell.com/techlit/pdf/60-0000s/60-2171.pdf
one of those should be pretty much like yours...
heatman101
May 06, 2010 | Carrier 38CKC036 Air Conditioner
Carrier air con. expansion valve 5 problems and 5 solutions
1. Mid to late 90's problems on Carrier coils leaking. 2. Problem with lication of TXV's on air handlers. When welded in they were located to close to the fitting where the suction lines were welded in to unit. The heat would cause them to fail.
Feb 21, 2010 | Carrier 38CKC042 Air Conditioner
Temp in my home will not drop below 81 degrees
Air Handlers differ in the way they adjust there variable speeds. Carrier you just plug into a pin. Trane has dip switches with directions on the fan housing. Before you try to adjust please kill power to air handler. Varriable speed are very sensative to voltage. If I new your air handler brand I could help. But just check the wiring diagram and they may ahve dirrections on there for setting speed. Need more help call back Rus
Jul 04, 2009 | Heating & Cooling
My outdoor heat will not operate. It is a Carrier 38YRA042330, with a Carrier Thermidistat thermostat and a Carrier Air Handler 40FFKB005300. I have an H5 error code on the thermostat will I put it in...
you need to go oside and look for a red reset button on the unit. you tripped the high ressure switch when you let your filter get that dirty. go check on this and when your done if it still is not working then ask me more.
Jan 25, 2009 | Carrier Heating & Cooling
Carrier Air Conditioner Infinity System - Air Handler Sweating & Duct Work Condensation
Either its not drainning mositure properly or low air flow across the "A" coils- caused by dirty filter .
Sep 12, 2008 | Heating & Cooling
We had a carrier infinity system put in place 2 years ago. A week a go we had a system failure and notification on our screen for system malfunction. It turns out that the damper control module failed...
if your air handler and ductwork are sweating, this tells me that the unit is operating too cold. The slower the airflow, the colder the temp. Your infinity unit is a wonderful machine! But I've seen many of these units that horizontal leak water due to airflow issues. The air handler(inside unit) has a true "variable speed" blower motor. Where we used to have low, med., high speed, now an 1100 rpm motor will have 1100 speeds(so to speak). Now after installation, the company should have sent the technician to set the system up by checking a TESP, total external static pressure. This info is located on the air handlers info on the front of the unit(sticker on panel). This verifies that the airflow is adequate and proper for your house and ductwork. If this is not right then blower motor damage may occur. Also, if you can imagine a cold can sitting on the table. If the temp in the air is warm and moist the cold can is cooler that the air it is sitting in. The can will sweat and a puddle will form on your table. Now, your air handler is running too cold, probably due to low air flow. Its sitting in a warm(er) moist environment, and sweats. It's all insulated but this won't matter due to infiltration of warm air through the insulation. Most people don't understand why too cold is a problem in cooling but this is one problem we have. And also, this unit may be leaking water from the condensate pan. I've had issues with this style. If it's not draining properly, the pan holds water and that water is pushed out of the pan by the blower. If the unit is not level, or down hill just a bit, towards the drain outlet, it will hold more water in the pan than its designed to hold. It also has a zoned damper? These zoned contrlloer/damper control modules can be installed anywhere, not just a closet. It would help if it's in a controlled environment, but not necessary if the machine is set up properly. I'm 99% certain you have an airflow issue! Get a second, third, fourth opinion. It may/will take more than 1 trip to fix this. Carrier corp. has dealers that sell/install Carrier machines. These companies have experience (ask them up front) with the infinity. And also have Carrier tech support. Ask for a TESP check before you schedule a service call. And any qualified tech won't mind explaining this process as you look over their shoulder as the work. You'll also been to get the duct reinsulated. I would contact your installer and ask them to rectify this issue, at their cost. Your contract with them should state a warranty, and also a "time subject for repair" if problems arise. If you are not satisfied with their answer, call your local/state license authorities. City inspection may/should work if you're inside city limits. Carrier also has field techs! But cost about twice as much as you're used to. Hope this helps!
Mar 04, 2017 | Carrier Heating & Cooling
Heating & Cooling Logo
169 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
