GPS Logo
A
Anonymous Posted on Sep 24, 2014
Can you put a lexus250 sat nav into a 220d without
Can you put a lexus250 sat nav into a 220d without one
Lawrence Oravetz
Level 3:
  • GPS Master 10,558 Answers
  • Posted on Sep 24, 2014
Lawrence Oravetz
GPS Master
Level 3:
Answers
10558
Questions
Helped
2699401
Points
29284
You'll have an antenna location problem. Running the wire requires removing the headliner before you drill holes in the roof. Then routing the wire once inside requires the removal of door sill covers and other plastic interior parts to install the antenna wire.
1 Related Answer
Anonymous
  • Posted on Aug 20, 2009
SOURCE: Lost Memory Card for Route66 Sat Nav
Get the SD card for any comuter store, and after you have to install the nav software on it, which for some information regarding the unit I will sell it to you for a rezonable price
6helpful
3answers
How do i unlock my sat nav, when i dont know the pin code, which my child has put on it
1.- Power off the GPS
2.- Press and hold the reset button
3.- connect the N?vi to an EXTERNAL power source
From the user manual
For the soft reset holf the lower - right corner while power on, wait still pressing the lower - right corner till the message appears.
9helpful
How can i update my guide sat nav
If the maps are on an sd card you may be able to put tom tom on but as for updates myguide no longer exist and so don't provide updates. Mine still works fine and any roads that have been built that don't appear on the sat nav i have managed anyway.
Can u play cds with sat nav on
Only if its a hardware based sat-nav, if its a head unit sat nav with a sat nav disc in then no.
Does the sat nav work without the disc in the head unit... if not then no.
Sat nav
sat nav,??ive driven for years without it ,open window and ask or follow a bus ,thats my favourite
1helpful
2helpful
2answers
Hi.I have Garmin 755 and need to help me.When i bought it ,it's worked good .It has 8 month old. The problem is,when i turn on ,working fine 1 minute, after that i saw on it that: Acquiring...
I'm not sure if you are aware but there have been recent warnings that sat navs may start to fail and will stop working all together by 2010.
May 22, 2009...3:34 pm
Are all sat-navs going to fail in 2010? Jump to Comments
sat_nav_fail.jpg?w=300&h=200 Sat-nav systems could become defunct next year, according to a report from the U.S. Government.
It reckons a lack of investment and development into the U.S. Air Force’s GPS (Global Positioning System) will cause the failure.
But the U.S. Air Force said sat-navs will carry on working as normal. So who’s right?
I’ve been meaning to buy a sat-nav for some time due to my girlfriend’s “interesting” map-reading skills.
There’s no doubt reading a map can be more rewarding, but the convenience of using a sat-nav is a welcome one.
But recent claims from the U.S. Government’s Accountability Office (GAO) concerned me slightly. It warned the 20-year-old Navstar GPS system is in urgent need of an upgrade.
The GAO criticised the U.S. Air Force Space Command for offering the service for free, and said the lack of investment meant both military and civilian systems could be affected.
Apparently the GPS system overran its budget by £562 million and the next satellite is due to go into orbit in August 2009 – almost two years behind schedule.
“It is uncertain whether the Air Force will be able to acquire new satellites in time to maintain current GPS service without interruption,” the GAO said.
But the U.S. Air Force Space Command left a comment on Twitter declaring there is nothing to worry about.
“Be assured, the issue is not whether GPS will stop working. There’s only a small risk we will not continue to exceed our performance standard.
“Since 1995, GPS has never failed to exceed performance standards,” the U.S. Air Force Space Command said.
Drivers across the world will be affected if sat-navs fail to operate in 2010.
If the satellites do go down, a new EU sat-nav system called ‘Galileo’ could be in big demand when it goes worldwide in 2013.
Until then, I’m going to put my faith in the U.S. Air Force and take the plunge with a sat-nav.
This does worry me, because I have had simliar problems with my work's sat nav, even on clear sunny days.
1helpful
Garmin nuvi 760, don't seem to be able to load music onto it
I have a 660, and it works fine from the sd card. Make sure the files are .mp3 and that you toggle the source from the mp3 player screen. Can you see the files in browse mode ?
I put 3 music cd's in the sat nav!!
go back to dealership truck should still be under warrenty
1helpful
2answers
Blaupunkt sat nav problem
when insert the adress it doesnt recognized and give wrong direction
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
