Question about Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by
Toilet fill runs periodically works well but wastes water
Kohler 2 piece with Ingenium fill valve. Installed about one year.
Recently noticed water running every 10 minutes or so. It stops after
a few seconds. Repeats
  • 224 Answers
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Posted on Jul 04, 2009
Kohler toilet troubles
The holes around the inside of the bowl may be clogged, try using some CRL and scrubbing the holes with a good stiff brush.
Apr 09, 2014 | Kohler Toilet - One Piece with Ingenium...
Float does not trigger valve to stop water - continues to run even though tank is full
What kind of flush valve is it? kohler.com shows a couple of different towers with their ingenium toilets. Is it a Kohler item or is it a Fluidmaster?
Usually you adjust water height by turning a threaded rod that runs up and down. See page 5 of this pdf
http://www.plumbersurplus.com/pdf/1058802_2.pdf
Jan 29, 2011 | Kohler Toilet - One Piece with Ingenium...
Fill water squirts out "vents" at top and even
replace the valve rubber at the top of the inlet control
Sep 06, 2017 | Kohler Toilet - One Piece with Ingenium...
After each flush, the tank fills but the fill valve doesn't stop and the water keeps running into the toilet. How could I adjust the fill valve?
Usually the problem is dirt in the fill valve and not an adjustment problem...
depending on which valve you have it can be taken apart and cleaned out... just remember to turn off the water supply before taking the fill valve apart...
Jul 28, 2010 | Kohler Toilet - One Piece with Ingenium...
Toilet keeps running even when manually lifting floater to max
check handle to ensure no tension is on the flapper chain when not being flushed. check flapper to ensure positive seal to flush valve. check water level to ensure not overflowing into flow valve. if that's the case, lower water height.
then if still doesn't work, change flapper,
all else fails, change flush valve.
good luck,
steve
Oct 03, 2009 | Kohler Toilet - One Piece with Ingenium...
K3367 one pice toilet harmonic vibration
check your water preasure. it sounds like it's to high and you should adjust your prv
Sep 13, 2009 | Kohler Toilet - One Piece with Ingenium...
Replaced the flapper with a new one and the toilet will lose water until it triggers the fill valve in maybe an hour. Is the gasket betwenn the tank and the cistern leaking slowly?
check the fill tube. sometimes they crack, put some food coloring in the tank and that will help you find leaks too. gently squeeze the tube and see if you see water running down the inside of the tube
Aug 02, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
1,254 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
