Question about Samsung Computers & Internet
How do i get the laptop to see a camcorder using the hdmi port?
    Scholar:
  • 84 Answers
HDMI will only support video & audio not data transfer. It is not like USB or firewire. The HDMI port on both you laptop and the camcorder allow you to connect these devices to a HD TV or monitor thats all I'm afraid
Posted on Jul 03, 2009
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
Will a sony HDR-SR10E camcorder support a firewire IEEE 1394 cable
hi,
No, sorry but this cam doesn't have FW port...
if it is for access to your records for editing, use USB
If it is for streaming, broadcasting or recording on a PC, use the HDMI output and HDMI capture card...
that's all...
cheers,
mich
Nov 02, 2012 | Sony HDR-SR10E HDD Camcorder
What kind of parts connect to connector2?
For this laptop?
http://www.msimobile.com/level3_productpage.aspx?cid=3&id=152
Right side of the laptop? 4th and 5th port back from the Front?
They are USB ports. A USB cable plugs into them.
Left side of the laptop? 2nd port back from the Front?
It is an HDMI port. An HDMI cable plugs into it,
http://en.wikipedia.org/wiki/HDMI
Plug an HDMI cable into it, then to an HDMI port on an HDTV that has this port.
X-Box, PlayStation, and Wi uses an HDMI cable, and plugs to this port on the laptop.
Just some of the uses.
Regards,
joecoolvette
Aug 10, 2012 | MSI ATHLON NEO MV-40 (L2100-036US) PC...
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I need to connect it to a hdmi port, is there a cable like that?
this camera does not support hdmi. so u cant connect it to the hdmi port
Feb 13, 2011 | Sony CCD-TRV238E Camcorder
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
Cant connect laptop to tv
Hey
If you're using a newer laptop look for either a HDMI (looks like elongated USB port) port or a DVI (a female port similar to a serial port but wider. Usually a white) port on the back/sides of your laptop.
If it's an older one, Look for an SD port (Resembles a PS/2 port which you plug the mouse in).
That being said, your TV must be able to pair with one of the above ports.
HDMI -> HDMI (using a HDMI cable)
DVI -> DVI
SD cable usually splits into three, Red, Yellow and White pins. Two for the LEFT and RIGHT audio channel and the other is for the video.
You might also be able to find converters from one format to another.
Hope this helps.
Cheers!
Dec 19, 2010 | Computers & Internet
How do I connect my laptop to tv to use as monitor
It depends on the laptop and the TV. If both have a VGA port, then use a VGA cable between them. Make sure the VGA port is enabled on the computer (possibly in the BIOS) and then set the monitor properties. You may need to reboot the computer to get the TV on.
If the TV has HDMI input and the laptop also has an HDMI port then you need to check the TV specs. Some HDMI ports can accept a signal from a computer (often labeled HDMI/DVI) and others don't. If the HDMI port is compatible with a computer source, then use an HDMI cable between the two. Again make sure the port is active. If TV's HDMI port is not compatible with the computer, you will need a converter.
If the TV doesn't have a VGA port (and the laptop doesn't have any video port other than VGA), then you will need a VGA to component video converter (or VGA to composite video) depending on the inputs of the TV. See http://www.svideo.com/pctocomponent.html for some converters.
Note: the converters are needed since computers output in a different format than the TV input understands. For analog, the computer is RGB and the component video is YPbPr.
A few media PCs might have a TV out port. This would eliminate the need for a converter. Check the specs for the cable you need.
I hope this helps.
Dec 10, 2010 | Televison & Video
Transfer from recorder to projector screen
It depends of what uotgoing ports you have on your jvc and what incoming ports there is on the projecor.
For example,If there is an S-video out from your jvc and there is an S-video incoming port on the projector you using an s-video cable.
If there is an hdmi outgoing port on yuor jvc and an hdmi incomming port on the projector you using an hdmi cable.
There are hdmi cable, dvi cable, s-video cabe, component cable and composit cable.
Good luck
Dec 04, 2008 | JVC Everio GZ-MG360 HDD Camcorder
Movie transfer
hey emron,
this usually happens if you dont have a driver for that cam in your laptop. as long as your laptop doesnt recognize you cam, try jumping from one usb port to another. when the new hardware wizard appears, this will help you to connect that to your system.
Apr 16, 2008 | Sony Handycam CCD-TRV615 Camcorder
Computers & Internet Logo
69 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
