Question about Hotpoint HSS25GFP Side by Side Refrigerator
Our hot point refrigerator ctx16csxkrwh is leaking water from around the light
  • Hotpoint Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezerour hot point refrigerator ctx16csxkrwh is leaking - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 25, 2010
Water is leaking from under the freezer door. Hot point side by side refrigerator. Model no. HSS25GFTC BB.
If unit doesn't have any water lines attatched then remove panel below fridge door and empty the water catch tray that is usually under all refrigerators
Nov 04, 2014 | Refrigerators
I have a GE refrigerator which leaks water. Point of origin of the leak is unknown but the water drips down the interior and pools at the bottem until it overflows and drips on the floor from the fro
You have a frozen drain in the freezer side of frig....take back panel off in freezer and you'll see your build up of ice take out ice and pour hot hot water down drain....make sure clear and clean then you're done....easy peasy....
Oct 02, 2012 | GE Refrigerators
Water leaking inside
Hi,Open the freezer compartment, unsrew the two nuts. pour a little warm water to defrost the bult up ice on the freezer compartment. At the estreem end, a shining drain pan might full of iced remove the ice at the center of the pan you will see a hole blocked with ice, pour hot water on it till all melted away. open the back of your refrigeration there is a water drain hole, around the left hand corner. see if the hot water driping off. this resolve the problem.
Thanks and Good luck
Jun 04, 2010 | Maytag MTB2176 Top Freezer Refrigerator
Our Haier refrigerator is leaking water below the freezer. It is coming from only one side. How to fix?
The reason for your fridge to leak water on floor sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a boaster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear.
Thank you for contacting Fixya.com
Aug 11, 2009 | Haier Refrigerators
There is water leaking out of my bottom freezer
Aug 11, 2009 | Candy CPCA240FFK Bottom Freezer...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Hot point refrigerator
Water can form in a fridge in the form of condensation.
There is a catch basin in the bottom of most refrigerators to catch this condensation and it may be overflowing.
Check that the door is closing all the way and the gasket that seals around the door isn't messed up some how.
If the 'fridge has an automatic ice maker, turn the water off to it and see if the leak stops.
Please give rateing after reading this solutions
Jul 04, 2009 | Refrigerators
Pure water dispensor leaks around the edge.
hi, this is a seal leak. its located behind the water release point. it could also be cracked, the assembly that is, but im sure its just a seal issue.
Feb 12, 2009 | Samsung RF265AA Bottom Freezer French Door...
The water in the in-door dispenser is coming out hot
If this freezer is like most, the water going to the dispenser is looped around many times in the refrigerator section near the back. Make sure that this is still true. It must have a lot of water cable in the refrigerator section so that the water has time to cool down before it goes out the dispensor. If for some reason the water tube is touching either the compressor motor or another hot part of the external refrigerator it could cause it to be to hot to cool down in time during its travel through the refrigerator as well as it will start to warm up the refrigerator section as well.
Also, I am sure you have tested, but make sure that you are plugged into the cold water supply and not the hot water supply. Check the water at the connector and see what the temp is at that point before it enters the refrigerator.
My guess is that the coil of water tubing that is usually in the back of the refrigerator section has been either lessend in length or the water entering the refrigerator is too hot to be cooled down in time before it reaches the dispenser.
hth
Feb 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Fan not working and sides are still hot
For your water flow problem and leak; Check in back of the refrigerator bottom right side facing the back. You will see two plastic tubes, one is for the water dispenser and the other is for the ice maker. Check for a loose connection at that point for the water leak.
May 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
106 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
