Question about Kenmore Refrigerators
Hi i have a kenmore model #58585892.the problem:
Hi i have a kenmore model #58585892.the problem: the water does not come out from the water dispenser can you help me solve this problem?
  • 4,070 Answers
Disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. If water does come out-
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
Posted on Jul 03, 2009
Pressure switch for a kenmore model 11047789701
Hi.
The original part (p.n.W10415587) is scarcely available . A replacement water level pressure switch can be used in place of the original.
Pressure switch.
KENMORE ELITE Residential washer Parts
Kenmore Elite Water Level Switch-Forum Discussion
Regards.
Ginko
Dec 15, 2011 | Washing Machines
Need a water dispenser lever part number for a kenmore side by side model 253.52614200
Your part number is 241682202 also here is a link for you water paddle if this helps.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 29, 2011 | Kenmore Side by Side Refrigerator
I have kenmore refrigerator model- 253 67172504. water inside
Hi. The problem here is going to be with the defrost drain. Follow tthis link to my tips for full details on fixing this problem. Mike
http://www.fixya.com/support/r3557045-how_to_clear_a_blockage_in_the_defrost_d
Dec 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Washer won't fill with cold water
hi..
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open..
thank u
rate me..
Aug 15, 2009 | Kenmore Washing Machines
INVENSYS CONTROL FOR KENMORE ELITE SIDE BY SIDE
Hi, you can purchase replacement part on amazon, here: Amazon com KENMORE ELITE INVENSYS CONTROL I hope this was helpful. Cheers
Apr 27, 2009 | Kenmore Refrigerators
Kenmore water on floor
Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
Jan 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore 80 - water leak not from hoses - could it be the pump?
Hi Gleen you probably need to remove the rear cover to expose the in side of machine.
Note if you could post a model number I could tell you for sure what would be the best way get to the pump.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore fridge ice maker not working
only two things this could be, either your water valve is bad or your icemaker is bad. you can get a kit which comes with both for a little over a hundred bucks, and you can change them yourself.
Mar 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
377 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
