Question about Lexmark X6150 All-In-One InkJet Printer
Encoder strip has come out
How do u set the encoder strip on Lexmark X6150? It came completely out. i do have it.
    President:
  • 2,306 Answers
Look inside, there should be a spring on the left and a hook on the right. The arrow points up on the left side and you have to feed it thru a rectangular hole at the back of the carriage assembly and then the left spring and right hook.
Posted on Jul 03, 2009
Reinstall the encoder strip
Here's an article on the Lexmark website that will give you an idea on how to reseat the encoder strip on your Lexmark X6170 printer.
Error 0502 on the Lexmark X6150/X6170 Printer LCD Display
I hope this information has been helpful.
Dec 12, 2011 | Lexmark X6170 All-In-One InkJet Printer
The encoder strip has come off, how do I put it back on as I don't know where exactly it is supposed to go!!!
This article in the Lexmark website will give you an idea on how to re-seat the encoder strip in the carrier assembly: Printer Cartridge Stalls or Is Blocked
Apr 14, 2011 | Lexmark X6150 All-In-One InkJet Printer
My Lexmark X6170 won't print or partially prints e-mail. Also it won't copy in black but will copy in color? When this happens I get the 0502 error message. Any idea as to what is wrong and how to...
The 0502 error code indicates either a faulty cartridge is detected or the encoder strip (transparent strip) is dislodged from its position. Refer to this article in the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display to determine and resolve the problem. Thanks.
Feb 16, 2011 | Lexmark X6170 All-In-One InkJet Printer
Lexmark 6170 code 0502. How to correct? fgoff
The error could be caused by an unseated encoder strip or by a faulty cartridge. Please refer to this article on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. Hope this helps. Thanks.
Jan 18, 2011 | Lexmark X6170 All-In-One InkJet Printer
Only prints to four lines of page. error 0502 comes up on screen. thanks
The 0502 error indicates either a problem with the encoder strip or a faulty black/color cartridge. Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display to determine the cause of the problem and resolve the issue. If error continues even after following the steps, please contact Lexmark technical support for additional assistance. Thanks.
Jan 07, 2011 | Lexmark X6150 All-In-One InkJet Printer
Receiving printer error code 5020..wht does it mean and how is it corrected?
The error indicates either an unseated encoder strip or a faulty black or color cartridge. Please refer to this article on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. If error continues even after following the troubleshooting steps in the article, please contact Lexmark technical support for additional help. Thanks.
Dec 27, 2010 | Lexmark X6150 All-In-One InkJet Printer
How do I fix hardware error 0 502?
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Feb 10, 2010 | Lexmark X6150 All-In-One InkJet Printer
What is an error message 502?
The 0502 error can be caused by four different issues:
  • A contaminated encoder strip
  • An unseated encoder strip
  • A faulty black/photo cartridge
  • A faulty color cartridge
If the printer is still under warranty, it is best to replace it, as error 502 is usually recurrent. Otherwise, please follow the link below to the Lexmark website for a detailed troubleshooting guide for error 502:
I hope this helps.
Nov 19, 2009 | Lexmark X6150 All-In-One InkJet Printer
My lexmark x6150 says hardware error 0502
Hardware Error 0502 on LCD Display
Cause
The encoder strip may have gone out of range of the sensor, or it might be dirty.
Resolution
You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.
    2. Disconnect the power cable from the back of the printer.
      Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones you need to clean. IMPORTANT: Use a dry tissue.
    11. Perform the hardware test, first without the cartridges and then with both cartridges. Click on the applicable article link below.
      How to Perform the Hardware Test on the Lexmark X5150
      How to Perform the Hardware Test on the Lexmark X6150/X6170
Thank you
Nov 26, 2008 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X6150 All-In-One InkJet Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
