Question about Miele Dryers
Miele 1570C W/D dryer door pops open
We're having problems now as the dryer door continually pops open during the cycle. We had a service tech come out and he said he fixed it by tightening a screw, it didn't even complet one cycle before it popped again. Has anyone found an answer to this problem?
2 Suggested Answers
ned_san_jose
  • 234 Answers
SOURCE: Miele 1570C washer/dryer. The dryer
There is a door catch on the body. Try spreading it out. put a slotted screw driver in it and open the catch just a bit. If that doesn't work, then you need to get a catch assembly. It's less than $10 and takes 5 minutes to put in. good luck :)
Posted on Jul 08, 2009
Dryer door pops open during cycle
Good Afternoon Friend,
I understand that your Frigidaire dryer door keeps popping open during the cycle. I suggest making sure that the door has been completely closed before starting the cycle. If this is done, and the door is still popping open, there might be something going on with the door latch. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the door keeps opening mid-cycle. Hope this is helpful.
-Best regards-
WP
Jun 07, 2014 | Frigidaire Electric Dryer
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
Miele t9820 service manual
did you get your software update done during the campaign? Call miele for the software update. while the tech is there, ask him any question you want. it is free of charge, and it is a safety issue on that dryer. 800 999 1360. dsc software update.
May 02, 2012 | Miele T9820 Gas Dryer
My dryer keeps stoping during the cycle and the door opens. Do you have any suggestion? Thank you very much
most likely you have a bad door switch your dryer will stop when the door is opened another way of by passing this switch would be to find it onthe inside of your dryer and connect the two wires together this is only a temporary fix your dryer would always run even withthe door open by doing this best thing to door is look online marone appliace call them give them your model number order a door switch ad you might even need a door latch also if your door is not staying closed hope this helps
Jul 13, 2010 | Miele Novotronic T220 Electric Dryer
Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Jun 27, 2010 | Miele 24 in. G693 Free-Standing Dishwasher
Miele T230C do no start
If start LED does not blink, most likely fault is your door lock.
Jan 04, 2010 | Miele Novotronic T230C Electric Dryer
Problem with Miele Touchtronic T 9800 Dryer end indicator
You've most likely got a bad control board. You'll have to install a new one which can be a bit expensive but cheaper than a new machine by far. I recommend getting a service tech to replace it for you however if your handy you could replace it yourself. Just get the new control board from an appliance parts store, they should be able to look up which board you need as long as you bring them the model number.
Dec 15, 2009 | Miele T9800 Electric Dryer
Miele 1570C washer/dryer. The dryer door continually pops open during the cycle.
Jul 03, 2009 | Dryers
During the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Feb 25, 2009 | Dryers
Door pops open during wash cycle
this is joyce
What I would do in this situation is fix the door lock first before I would do another load of clothes. you can go to Kenmore.com put in your model # and download your manual to your machine if you want to fix yourself
or you can call service tech out. I will help you find one in your area if you need.
thanks,
joyce
Feb 04, 2009 | Kenmore 44072 Front Load Washer
Dryers Logo
113 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
