Question about Nvidia GeForce 6200 AGP Graphic Card
Vertical Bars on some displays, which is like an old b&w tv.
I have a nVidia AGP 6200 graphics card on my Dell 8200 Dimension, 1.5 GB RDRAM. I am running Vista 32 bit on this computer and this did not occur when I first installed it and don't know exactly when it did happen. When I run a video, it usually has vertical bars. Often, if I "Minimize then Maximize, it stops. With games, such as "Solitaire" or other MS games, it also has the grayscale bars also, but moving off of the main screen will cause it to light up in the intended color. Any suggestions?
    Novelist:
  • 79 Answers
I would upgrade the graphics card driver from the dell website or go here:
http://www.nvidia.com/object/win7_winvista_32bit_186.18_whql.html
and download the latest nvidia driver.
If that does not work, power down the PC. Unplug the power cord, and press and hold the power button for 2 seconds to drain the capacitors. We are going inside.
Open the case, and get ready to pullout the videocard assuming it is a discrete card and you do not have integrated Motherboard graphics, if you do then forget about this.
Be sure to touch the metal case several times to discharge any static you may have and I RECOMMEND you not to work on the carpet.
Unclip the graphics card from the motherboard (there is a small clip at the end of the AGP port. Now the card should come free (although you may need to take out a screw depending on how the case is designed). Once the card is out plug it back in carefully.
Plug everything back in and boot up. If there are still bars then it may be time to get a new AGP card. There are many many on EBAY.
Good luck
Posted on Jul 07, 2009
What memory (does) it use?
Jokodi Haynes,
The Dimension 8200 memory specs are listed below.
Memory
Architecture RDRAM
Memory connectors four
Memory capacities 64-, 128-, 256-, and 512-MB non-ECC RDRAM
Minimum memory 128 MB
Maximum memory 2 GB with Microsoft® Windows® 2000 and Windows XP; 512 MB with Windows Millennium Edition (Me)
Memory type PC800 (non-ECC)
Memory speed 40 ns or faster
BIOS address F8000h
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 29, 2016 | Dell Dimension 8200 PC Desktop
I have a Sony Vaio VGC RB-40 Desktop PC. P-4 3.00GHz. 2.00GB. Ram 32 Bit system Win 7 Home Premium 300 Watt power supply I need a video Card 1GB DDR3
Hi,since your computer is P4 3.0ghz,your looking for agp 6200 graphic card..and not the 1 gb ddr3 because this is pci-e and its not compatible with your slot..I can offer to you is the 256 mb agp video card,coz its hard to find now the 1gb ddr1 coz its all absolute now.thanks
Aug 20, 2011 | Nvidia GeForce 6200 AGP Graphic Card
I have windows 7 Operating system installed on Intel Original D865GBF motherboard. The processor is 3.2GHZ. Ram is 2 GB dual channel (!GB x 2). I have added a graphic card PNY Ge Force NVidia 6200 AGP. The...
sounds like yo had the same Probles that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the montior cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is runing with your card you can also see that fron the about nvidia you must have the driver for the card installed to do all this.. hope I helped
Feb 27, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Geforce 6200 / dell dimension 4600 resolution problem
if this is a relacement for an old card 1st make sure the old drivers are ubisnatlled and the goto www.nvidia.co.uk and install the latest wqhl drivers and that should remidy it you may also need to reset you monitor settings
Feb 02, 2010 | XFX GeForce 6200 Graphic Card
I recently bought a Nvidia GeForce 6200 256Mb AGP card to replace a 5200 card so my daughter can run her school assistance programs. its my old computer and I never had any problems with the old card...
Sounds like a Driver Conflict.
Still have the old 5200 drivers in there?
Did you install the drivers for the 6200, BEFORE you physically put the graphics card in? (Not shouting)
Let's say you did remove the 5200 drivers, before you installed the 6200 graphics card.
BUT,
If you physically install the 6200 graphics card, BEFORE you have installed the drivers, Windows 'sees' a new device, and hurries up to match one of it's generic drivers.
(Windows has thousands of drivers!)
Now you come along, and install THE drivers for the 6200. Windows has a drivers conflict.
Windows: "Which drivers do I use? These, or THESE?"
Makes for a garbled graphics display as you've described.
If the above is true, start over.
Go to Add/Remove Programs, and Remove the Nvidia software. All of it that has Nvidia next to it.
(THIS, is provided of course, that the computer HAS Integrated Graphics, and does not just use a graphics card. You will be plugging the monitor, into the VGA port in the I/O area, on the back of the computer temporarily, if this is true, and this computer has Integrated Graphics)
(Start>Control Panel>Add/Remove Programs) If there is more than one Nvidia program listed, Do No restart the computer each time you remove one. Do Not restart. Read on)
After all Nvidia software has been removed, close Add/Remove Programs, close Control Panel, and return to the desktop screen.
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. (Count, 1001,..1002,..1003,..1004,..1005) Let go of the Power On button. Do this procedure Two more times.
What you are doing is clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings.
Open the case. TOUCH the metal frame of the case to relieve your body of Static electricity. Remove the 6200 card. Plug the monitor into the back of the computer into the VGA port. Leave the case open, you'll be going back in there.
Plug the computer into power. WAIT 1 minute, then turn it on. After Windows has fully loaded, install the GeForce 6200 drivers from that CD disk. Do Not restart.
Shut down normally.
Unplug from power. Touch that metal frame again. Install the GeForce 6200 card. Close the case. Plug the monitor into the GeForce 6200. (You did plug the monitor into the 6200 the first time, right, and not the VGA port?)
Plug the computer back into power. WAIT 1 minute. Turn the computer on. Go to Start>Nvidia>Nvidia control panel, and set the settings.
Aug 15, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Replacing a Graphics card: Presently a GeForce 420 (64mb) upgrading to GeFroce 6200 (256mb). System is a Dell Dimesion 8200 w/Windows XP at 2GB with 100+ GB free. Will the card work? Tim
If the type of card is the same,and will fit into the slot,such as AGP or PCI or PCIe, then it wil work after you install the new video card drier for your operating system of windows.
Dec 27, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Upgrading Graphics Card
So your dell only has a AGP slot.
You need a AGP card
On nvidia side you can get
The geforce 6000 - series
Geforce 7000 series
On Ati side you can get
Radeon x1000 series
Radeon HD 2000 series
Radeon Hd 3000 series
Remember they have to be AGP
May 26, 2008 | Dell Dimension 8100 PC Desktop
Replacement Video Card - Dell 8200 w/ NV25
I have a couple of graphics cards that will do the trick. Email me back and I will help you out.
May 14, 2008 | Computers & Internet
Nvidia GeForce 6200 AGP Graphic Card Logo
171 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
