Garden Logo
A
Anonymous Posted on Sep 23, 2014
My poulan 2075c chain saw won't start. Pull recoil rope will not pull out smoothly.
I took the spark plug out and the recoil rope pulls smoothly the way it should.
Decalescence Point
Level 2:
New Friend:
  • Expert 45 Answers
  • Posted on Jan 08, 2015
Decalescence Point
Expert
Level 2:
New Friend:
Answers
45
Questions
Helped
17139
Points
131
I would suspect possibly you have the incorrect spark plug installed which is allowing piston to contact it preventing complete rotation of engine.
Or possibly the engine has so much compression that you are not used to it and it is making you believe the engine will not rotate with spark plug inserted?.
5 Related Answers
Anonymous
  • 61 Answers
  • Posted on Jul 04, 2009
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Anonymous
  • 4088 Answers
SOURCE: PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Anonymous
  • 2220 Answers
  • Posted on Sep 17, 2009
SOURCE: starter rope will not pull. Will pull smoothly
If I understand what you are saying... The starter pulls smoothly with the starter cover removed or when installed and the plug removed (no compression or spark). If this is correct I think your saw's timing has slipped or maybe a defective decomp valve. Time to visit your neighborhood chainsaw seller/mechanic.HTH
Lou
Testimonial: "cheers"
Anonymous
  • 4088 Answers
  • Posted on Apr 21, 2010
SOURCE: recoil starter
If the end of the cord won't hold a knot to keep it in the reel, try melting the very end of the cord with a match to form a small lump. If the cord is too short so that you are coming out to the end before getting a good run-up in the starter, replace the cord with a longer piece (obtainable from any servicing dealer). Buy the same diameter of cord. Hope this helps!
Anonymous
  • 2220 Answers
  • Posted on Jan 13, 2011
SOURCE: My Poulan 14" chain saw has become difficult to
If you have more questions or need additional help pleasereply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa. gif,gif89a%12%00%12%00%b3%00%00%ff%ff%ff%f7%f7%ef%cc%cc%cc%bd%be%bd%99%99%99zyzrur%00%00%00%fe%01%02%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%21%f9%04%04%14%00%ff%00%2c%00%00%00%00%12%00%12%00%00%04x0%c8i%2b%1d8%eb%3d%e4%00%60%28%8a%85%17%0ag*%8c%40%19%7c%00j%08%c4%b1%92%26z%c76%fe%02%07%c2%89v%f0%7dz%c3b%c8u%14%82v5%23o%a7%13%19l%bcy-%25%7d%a6l%df%d0%f5%c7%02%85%5b%d82%90%cbt%87%d8i7%88y%a8%db%efx%8b%de%12%01%00%3b
Very difficult to pull starter rope why??
This could be a lot of things. IF the fuel mixture is not right then the wear on the engine is excessive. Take the spark plug out and see if it is easier to pull. IF it is then the compression is too high and this could be from timing. If neither or those work, the clutch might be bad.
Poulan pp5020av. the pull start binds up.
When you remove the recoil shoot a little oil on the moving parts. sometimes they get dry or even rusty and binds.
Starter rope hard to pull. It's not smooth and takes a lot of effort.
Make sure the brake is off and retest. If brake is off and still difficult to pull, remove the side cover, chain, bar and retest. If still not right (remove sparkplug), remove the muffler and make sure that the spark arrest screen is clean and verify that the cylinder and piston look clean and smooth by looking into port. You can clean the cylinder by spraying wd40 and pulling the rope untill it all comes back out. Verify that the rope pulls smoothly before you reinstall the spark plug. If all looks good, reinstall muffler and retest. If the compression is normal, it should be rather hard to pull thru the compression stroke. Reinstall bar and chain for final test.
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
1helpful
Chain saw won't start
Before you try to start it, push the primer bubble on the side 3 or 4 times, then pull the choke all the way out. On poulans they can be tricky. When pulling the choke button out, make sure it does not go back in. After you pull the crank rope and you hear it "hit" push the choke back in and pull the crank rope again. It should start after that. If it still won't start, check for a faulty spark plug.
1helpful
Chain saw won't start - pull starter pulley hard to pull?
If it worked fine the last time you used it, then pull the spark plug and try pulling the rope. See if it's easier or if gas shoots out of the plug hole. I've seen this happen when the diaphram in the carb goes bad from sitting over winter. It loads up the cylider with fuel and makes it very difficult to pull the rope. If there is no fuel in the cyliner and it's still hard to pull, make sure there is nothing binding the clutch/sprocket. I've had chucks of wook lodged in there that caused it to bind the crank output, which resulted in a hard pull on the rope as well.
1helpful
Poulan Pro 18 inch saw. Once the unit is warm it
start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
1helpful
Poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
2helpful
Recoil spring on homelite chain saw doesn't retract pull rope
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
