Question about UC-Logic WP8060U (689076313025)
Will not load a windows xp driver
Will not install a windows xp driver from the supplied installer disc, comes up with a message saying that the item is not XP labeled
  • eric_rigg Jul 03, 2009
    I am trying to install a driver for windows xp for the WP8060U graphics tablet
  • 34 Answers
Hi. What driver are you trying to install?
Posted on Jul 03, 2009
I am not able to install xp 2002 in my laptop due to 0*0000007B (0*F7B5F524,0*C0000034,0*00000000,0*00000000) error but i can easily install windows 7 or vista
Usually the main reason you can't install XP on a computer but you can install Vista or Windows 7 is because XP doesn't come with SATA drivers on the installation disc, you can put the drivers on a floppy disc or even format a USB stick to a floppy disc format, and press the relevent button at the prompt when windows is installing,
the only other method is to create an Nlite version of your windows CD, as this is against the terms and conditions issued by microsoft, i cannot go into this.
Apr 19, 2011 | Computers & Internet
How to install windows xp on dell core i5 inspiron 15r n5010
First, be sure you have your genuine copy of Windows XP -if not, you can contact Dell and ask them a copy of it
1)insert the XP disc on the drive then turn off the computer 2)Turn on again the computer and once you press the power button, keep on tapping on F12 3)You should be seeing the Boot Options. Select CD/DVD and keep on tapping on ENTER once you see the message: "press any key to boot from CD/DVD" 4)if you have done it succesfully, you should see a loading bar that says, Setup is loading files. 5)wait for it to load and Just follow the steps on this link:
http://www.blackviper.com/Articles/OS/InstallXPPro/installxppro1.htm
Apr 05, 2011 | Dell Computers & Internet
I wiped my hard drive using kill disk. I have a Windows XP home disc to install the operating system, but when I boot the computer, I get the "Error loading operating system" message and it won't...
when you boot the laptop, if you don't see a message that says press any key to boot from CD, your boot order is wrong.
Check your boot order, when you see the splash screen (logo) look for a message that says press a F1-F12 key to change boot order or if that message is not displayed, press the key to enter setup.
Look for an option that list boot order and shows your hard drive, CD/DVD and USB options.
Move the CD/DVD item to the top of the list and try again.
Feb 11, 2011 | Gateway Computers & Internet
Dfi-64 tc problems. i just to install xp (before was windows millenium )now each time when xp load appears a message saying that bus ide drivers does not installed but when i run the drivers disc...
when a person goes install windows xp they encounter the problem of not being able to find any hard disk drives installed as if they weren't connected. The hard drive is detected with no problem in the BIOS and also on start up POST, able to boot up Linux Live CDs but the hard drive is just not being detected in Windows setup. Here is the exact error message.
Setup did not find any hard disk drives installed in your computer.
Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue. To quit Setup, press F3.This problem is quite a common one and is simply due to the fact that when Windows XP was created, the SATA chipset itself and SATA hard drives weren't available to the masses, so support for it wasn't included in the XP setup process. As most computers within the last decade or so have some form of SATA controller, if you try to install Windows onto a SATA drive, XP won't recognize it because the drivers aren't present on the installation disc, so they need to be loaded manually for the drive to be picked up.
Thankfully there are a few ways to get around this problem and enable Windows XP to be installed onto a SATA hard drive so you can enjoy the extra performance and other functions like hotplug/AHCI etc. Setting the BIOS Correctly
The first and mos obvious method is to change the SATA Mode to IDE in the system BIOS. Most BIOS's for several years have included a fallback mode to enable a SATA drive to behave like an IDE drive, and therefore makes it visible to XP during setup. The problem with this setting is it comes under several different names and can be found in different sections within the BIOS. It depends entirely on the computer or motherboard's make, model and manufacturer to know which setting you have and where it is. If you have a manual, it's certainly worth reading.
The most obvious thing to look for is a setting which can change the SATA controller to IDE or PATA mode, with options such as AHCI -> IDE or SATA/RAID -> IDE etc. Basically any option you come across to reduce the SATA/RAID mode to IDE/PATA should be the correct one. Don't confuse this option with a similar one which will disable the SATA controller completely. Here's some names we found it could be under in a few motherboard manuals we looked at:
Integrated Peripherals > SATA Devices Configuration > SATA Mode > [IDE]
Integrated Peripherals > Serial ATA Function > Base
Storage Configuration > SATA Mode Selection > Emulated PATA Mode
SATA Configuration > SATA Configuration [Enhanced] > Configure SATA as > IDE
Integrated Peripherals > South OnChip PCI Device > SATA Controller > IDE Mode
Using a Floppy Disk
If you're unable to change RAID mode to IDE or disable SATA in the BIOS, then the next option would be to download SATA/RAID drivers from your motherboard manufacturer's website, extract the drivers to a floppy disk and then insert the floppy into your computer during Windows XP installation. This method obviously gets around the problem of XP not having the drivers on the install CD by you providing them manually.
Windows XP setup won't recognize USB flash drives, so you need to have an internal floppy drive available, many USB floppy drives will also work though. As you can see in the image below, it clearly states that the SATA RAID driver is for use on floppy drives. You need to make sure any drivers you download are explicitly designed for putting onto a floppy and not a generic driver, usually the file will be around 1MB or lower which is a good sign it's likely to be the correct driver.
Insert the Windows XP CD and boot it up. You should see a message that says "Press any key to boot from CD..." Simply hit any key and it'll start to boot from CD. Pay attention to the next blue colored windows setup screen. When you see a message that says "Press F6 if you need to install a third party SCSI or RAID driver..." at the bottom, immediately hit the F6 key.
After loading some files, you will come to a screen that says the following:
Setup could not determine the type of one or more mass storage devices installed in your system, or you have chosen to manually specify an adapter. Currently, Setup will load support for the following mass storage devices(s):
< none >
* To specify additional SCSI adapters, CD-ROM drives, or special disk controllers for use with Windows, including those for which you have a device support disk from a mass storage device manufacturer, press S.
* If you do not have any device support disks from a mass storage device manufacturer, or do not want to specify additional mass storage devices for use with Windows, press ENTER.Make sure the driver floppy is inserted and press S. It will present a list of drivers which it read from the disk earlier. Select the appropriate driver and continue the Windows XP installation. The setup will continue and this time it will recognize the SATA hard disk drive in your PC. This problem is quite common when trying to install Windows XP on newer computers because most if not all are using SATA hard drives. After installing Windows XP, you can easily and automatically install all required device drivers using the DriverPack Solution disc.
If you thought it wasn't possible to use a USB flash drive instead of a floppy drive to load the drivers during the F6 phase, we have a solution that could !!!
Oct 04, 2017 | DFI CA64-TC Via 694T/686B Mainboard...
Need a recovery disc! i recently bought one with a completely erased hard drive. i have xp software and key dut need to recover disc prior to loading. any help?
If HP/Compaq cannot supply you with a recovery disc, then you can get around this.
Install Windows XP then download the device drivers for your model laptop and install them on your laptop. You can use a another computer with Internet access then copy and install them on your laptop.
Normal 0
You can download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Oct 09, 2010 | HP Compaq Presario C304NR Notebook
I am getting a blue screen with error message: stop: 0x000000024 (0x00190203, 0x8A7DC5B8, 0xC0000102, 0x00000000) message I have run many diagnostic tests and all come back normal. it will not start in...
You cannot see HD because there are no apropriate SATA drivers included in windows XP CD. So you need to create custom windows XP installation CD
To install windows XP in that laptop u will need to create custom windows XP CD, how will you do that:
  1. Download nlite from http://www.nliteos.com/
  2. Download drivers for that laptop
  3. Download service pack 3 for windows XP
  4. Install nlite for windows XP and run
  5. Follow instructions and include SP3 for XP, all the drivers for laptop and create ISO Image
  6. Burn ISO Image
  7. Install Windows XP
  8. Good Luck
Nov 25, 2009 | HP Pavilion dv5-1140us Notebook PC
Audio Problem
http://intel.driversdown.com/Intel-drivers/Intel-Desktop-Board-D945GCNL-HD-Audio-Controller-5605-Windows-Vista(32-64)-XP(32-64)-2000_77686.shtml
Intel Desktop Board D945GCNL HD Audio Controller 5605 Windows Vista(32/64)/XP(32/64)/2000
Installs the Realtek audio driver version 5605 for Intel® Desktop Boards.
IMPORTANT: Audio drivers may fail to install in Windows* XP 64-Bit Edition. Symptoms may include error messages, such as "Error in installation" or "Unknown error". Microsoft's Update for Windows XP x64 Edition (KB901105) fixes this issue. After installing this update, the audio drivers for Windows XP 64-Bit Edition will successfully install.
Apr 23, 2009 | Intel D945GCL Motherboard
Motherboard drivers
I contacted HP the other day for a problem while trying to load XP on a VISTA box. They sent me to this site.. and gave me instructions for resoluation or at least an attempt.. Hope this helps
Thanks David
Let me know it if works for your problem
Solution: The reason for this error message is that notebook has been shipped with SATA hard drive i.e SATA hard drive controllers. But Windows XP does not have built in SATA controller drivers.
To solve this problem we need to install SATA Controller drivers before we install Windows XP using a USB floppy drive.
Many customers are not ready to buy USB floppy drive and installation of XP is so complicated using USB Floppy drive.
We have found the driver for the SATA controller on Intel Website. Customer has used it and installed retail Microsoft Windows XP with SP2 successfully on his dv6500 notebook.
The same can be achieved in all the dv2500, dv6500 and dv9500 also DV2600, DV6600 and dv9600 notebooks.
Here is the link for the SATA drivers:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&lc=en&softwareitem=ob-39535-1&jumpid=reg_R1002_USEN
1. The file contains the Intel Matrix Storage Manager Floppy Configuration Utility.
2. This utility will create a floppy disk containing the RAID driver files for installation on a 32-bit operating system.
3. This floppy can be used to pre-install the Intel Matrix Storage Manager driver during the F6 portion of Windows setup.
4. You needs Microsoft Windows XP with SP2 Operating System disc and the USB Floppy drive.
5. After downloading the SATA driver in another notebook, you needs to extract and execute the file. It will help in creating the floppy disk that has the SATA drivers.
6. Boot with the Microsoft Windows XP disc and make sure the USB floppy drive with floppy disc is connected to the notebook.
7. At the F6 prompt, select F6 to install additional drivers which are not in-built in the retail Microsoft Windows XP Operating System disc.
8. When the prompt comes up to install additional drivers, insert the floppy and select the correct SATA Driver. It is Intel 82801HEM/HBM SATA AHCI Controller.
9. Once that is done, the rest of the installation runs as normal. There are only 2 drivers in the floppy disc that would work.
10. After the Operating System is installed in this manner you can install the chipset drivers for the notebook.
11. However for the other device drivers once Microsoft Windows XP is installed you may not have them from HP as these series are not released with a Microsoft Windows XP Operating System. The drivers like audio, ethernet and media card reader drivers etc.
12. Please be sure with EU that he might not have the other drivers from HP after installing the retail Microsoft Windows XP.
Note: Do not click on the link. Copy and the paste the link into the address bar of the web browser.
If the above solution does not resolve the issue, please login to chat support with the results of the above troubleshooting steps. Also, please use the same email ID.
Dec 07, 2008 | Compaq Presario Notebook
Windows Xp on Intellistation Z Pro type 6221
A restoration disc is not a conventional Windows OS disc (and vice versa), therefore it often cannot be used as if it were a true Windows disc. The restoration disc includes the OS, but it also includes every driver and other software product that came with your system. If Windows were the only item loaded on your system, then a Windows disc could serve as a restoration disc, but these days, using a typical restoration disc is an all-or-nothing process.
A restoration disc is your ultimate troubleshooting tool. Suppose that your copy of Windows becomes damaged from a virus or key applications become corrupted. Symptoms such as instability, crashing, indecipherable error messages, and impaired performance are extremely hard to diagnose by yourself—even if you have the help of a customer support technician on the telephone. If the most common corrective steps fail, you can always use the restoration disc to recover your PC back to its known-good, factory-fresh state.
Jun 18, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
Lexmark x1270 all in one printer will not install
windows xp home edition has problems running a lexmark, the xp pro dont its a windows problem do you have xp if so when it says needs install dont use the disk let the set up wizard take you to a site to down load the drivers i had to do the same with my X1150 all in one.
Dec 20, 2007 | Lexmark X1270 All-In-One InkJet Printer
UC-Logic WP8060U (689076313025) Logo
285 people viewed this question
Top UC-Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Chris
Are you an UC-Logic Computer and Internet Expert? Answer questions, earn points and help others
