Question about Canon MultiPASS F80 All-In-One InkJet Printer
I chagned two of the ink tanks BCI-3eM and BCI-3eC, magenta and cyan and now everything prints green. I have taken all the cartridges out and put them back in again, but still prints green. What do I need to do?
  • Canon Master
  • 365 Answers
The print head is bleeding over.
You can try and take it apart and change o-rings.
If not you need a new head.
Posted on Aug 04, 2009
Wrong Color Printing
Type "print nozzle test" in the search box and click Search. Perform a nozzle test, and if the colors match what are on the instructions, your print head and inks are OK.
(1) If the print head and inks check out OK, type "wrong colors on print" in the search box, and you will see several troubleshooting steps you can try.
(2) If the nozzle test colors are off, confirm that you are using BCI-6 inks for all three colors and the small black tank. You should only have a BCI-3 tank in the large black position. If you have all the correct inks, your machine probably needs to be serviced/ repaired.
Thank
Jan 09, 2014 | Dell 1320c Laser Printer
What is the ink cartridge numbers for the MP730?
Here are the codes for your cartridges: BCI-3eBk (Black), BCI-3eY (Yellow), BCI-3eC (Cyan), BCI-3eM (Magenta)
Dec 28, 2010 | Canon SmartBase MP730 All-In-One InkJet...
I think I put in a wrong colored toner cartridge. Pages printing in wrong colors. Can't find a list of the cartridges I should be using.
The make and type of cartridge is generally given in the users handbook/manual provided with the printer. If you do not have that ,you can log on to Canon web site and then go to support. Select your printer model and you can find the the specification of cartridge to be used with your printer. The list of the cartridges is given below: BCI-3eBk Black ink tank, BCI-6Bk Black ink tank, BCI-6C Cyan ink tank, BCI-6M Magenta ink tank, BCI-6Y Yellow ink tank You can also go the this link and download the manual if you do not have the same http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip4000#Overview
Nov 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My cyan ink won't print. i have tried EVERYTHING.
The printer cannot use photo inks like Photo Cyan or Photo Magenta. Be sure to use "BCI-6 Cyan" in position 5 - farthest to the right.
Nov 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon iP1800 not recognising cartridges
5 flashes says the printhead is not installed properly, you may need a new printhead,
Jul 27, 2009 | Universal Office Ink Tank Cartridge for...
Canon bjc-3000 will not print
You said that the light blinks 7 times. It means that the BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 26, 2009 | Universal Office Ink Tank Cartridge for...
How to replace ink cartridge in canon pixma IP1800
make sure that the ink cartridge is in the docking posistion on far left hand side of printer. press down firmly on the cartridge and then slide it out.
Oct 06, 2008 | Universal Office Ink Tank Cartridge for...
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
Canon Smart base MPC 400 Printer
This printer needs these cartridges: -
1. (BCI-3eB) Black Ink Cartridge,
2. (BCI-3eC) Cyan Ink Cartridge
3. (BCI-3eM) Magenta Ink Cartridge
4. (BCI-3eY) Yellow Ink Cartridge
I think you need to clean your cartridge connectors with alchohol and retry.
Nov 21, 2007 | Canon SmartBase MPC400 All-In-One InkJet...
Ink tank installment
Recheck by removilng an reinserting cartridge
perhaps several times Is the cartridge identical
to the original, does it fit tight and latch down
securely
Nov 16, 2007 | Universal Office Ink Tank Cartridge for...
Canon MultiPASS F80 All-In-One InkJet Printer Logo
89 people viewed this question
old marine
old marine
