Assuming you are talking about private servers, then you can use either cheatengine from cheatengine.org or wowemuhacker from deathsoft.com. If you are looking for a stat changer on official servers, then it will not work, since the stats are kept server side and are watched by Warden. Thats not to say it's impossible, however unless you are willing to learn to use and read WoW packets, using a packet editor such as wpe pro, then it is unlikely you will be able to find a simple solution.
Other references can be found at rpg-exploiters.com.
Looking for a replacement for a Logitech wingman force 3D Joystick used mainly with Microsoft flight...
(More)
Looking for a replacement for a Logitech wingman force 3D Joystick used mainly with Microsoft flight simultor.
Tenho um Lcd Asus VW193D, desde o inicio do ano de 2009, sem qualquer problema, e agora,...
(More)
Tenho um Lcd Asus VW193D, desde o inicio do ano de 2009, sem qualquer problema, e agora, após ter formatado, estou com um problema - NÃO LIGA ao Desktop.
Será que está mal configurado? o Windows é o Xp, e foi configurado com o Plug & Plug? Será que a ficha avariou? Será da Placa? Memória?
Por favor não sei o que fazer.
Já experimentei com outro monitor e o problema mantèm-se, ligou no início e após alguns segundos, desliga (c/luz amarela - parece suspenso) e já não liga.
Agradecida antecipadamente
Filomena Moraes
I need drivers for my insignia D400A. I do not have my original cd recovery disk. Can i download...
(More)
I need drivers for my insignia D400A. I do not have my original cd recovery disk. Can i download these drivers or recieve a new recovery disk.
I have an Alienware computer with a Newton N1000P-00 1000W power supply. The system has begun to...
(More)
I have an Alienware computer with a Newton N1000P-00 1000W power supply. The system has begun to ranomly power off, usually after less than <5min. I've bypassed the power bar and am straight in the wall, disconnected all external peripherals, all internal drives and memory, sound card and video card and it still does it. I've also cleaned any dust out. It appears to be a faulty power supply, it's less than two years old (but over the 1 year warranty, of course). It doesn't appear to be heat related, although that was my first thought, as it happens even if the system is cold. I've verified all fans are operational. I know my obvious option is to replace it, but perhaps someone is aware of a common problem with these and it's something I can fix? Thanks, Craig
I have a Vaio all-in-one VGC-LT15E with built in wireless Mouse/keyboard RF receiver. Would like to...
(More)
I have a Vaio all-in-one VGC-LT15E with built in wireless Mouse/keyboard RF receiver. Would like to change to different (ergonomic) mouse and keyboard, would I be able pair new devices to the built in receiver?
