Question about Jura Capresso Impressa Z5 Espresso/Coffee Maker
Jura Impressa E fails to dispense, then gives "open tap" message
My Jura Imressa is almost 1 year old. It has worked perfectly until recently. Each time I try to brew a cup it will grind and act like it is going to work, but then only a couple of drops of coffee dispense and the "open tap" prompt comes on.
I had the same problem, when I called their very helpful customer service, I was given these directions.
Take out the tray.
Inside the machine you can now see a flap hanging from the top.
Reach behind the flap, and you should feel a round object/filter. It has a little dimple sticking out in the middle.
Wipe the filter with a paper towel.
Put the machine back together, and voila you got your coffee brewing again.
Posted on Jul 07, 2009
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Jura impressa Z5 doesn't switch on anymore. A few days before just was displaying "maintenance" and then no more signs of life.
Search Results
    How to Fix Jura Z5, Z6 and Z7 - YouTube
    ? 16:03
    https://www.youtube.com/watch?v=HlCu5m9isT4
    Aug 18, 2013 - Uploaded by Parts Guru
    I changed the filter, pressing button for System Fill, get message System is filling. .... My Jura Capresso Z5's milk frother doesn'twork. When I ...
    Jura Capresso Z5 Impressa - No milk frothing - YouTube
    ? 1:05
    https://www.youtube.com/watch?v=_jF_8rNUn4A
    Oct 25, 2013 - Uploaded by Frederic Valiquette
    Hi all, My Jura Capresso Z5 Impressa is acting up. The milk frother doesn't work anymore. When I ...
    [PDF]Instructions for Use, Manual JURA IMPRESSA Z5 - Esperanza
    https://www.esperanza.ch/.../download_manual_jura_impressa_z5-gen2_...
    The IMPRESSA Z5 - Generation II Manual. The 'IMPRESSA .... 5 Preparation at the touch of a button. 40 ..... As coffee and coffee specialities are very important to JURA, we have compiled a ...... It doesn't matter whether whole milk or skim.
    My Jura Impressa Xs90 won't switch on and nothing is - Fixya
Jan 31, 2016 | Coffee Makers & Espresso Machines
Why won't it turn on?
Honestly, I've never even saw a Jura Capresso Impressa S9 Coffee Maker so excuse me that I won't provide you a specific answer, but maybe I can help you with some generic guidelines. I
According to your description, after 5 years it's presenting some problem.
About German language message, copy it to google search, between quotes and add word translate; see if you get some intelligible return.
Other trick to get a tranaslation is to send text to yoursel with gmail and select "translate"
Depending on content of that mysterious German message, probably you should look for some repair service. Maybe on your original warranty you have a listin of "authorized repair service" or the shop where you bought it can tell you where to take it.
Aug 29, 2015 | Jura Capresso Impressa S9 Coffee...
Display tap on Jura Impressa E75 say close tap, where is tap please
The tap is the dial on the left turn it, then it will turn the tap off. If it is repeating this then it may need to be decalcified.
Sep 06, 2012 | Jura Capresso Impressa E75 Espresso &...
Jura S90 hasn't been used for many years. Close Tap Message
When I got my S90 I didn't have a manual or any paperwork on it. I had the same problem and found that the Selector knob for coffee or hot water (in the upper right area) was on hot water. Once I turned it back to the coffee selection I could use the rest of the functions. I hope this helps.
Oct 22, 2009 | Jura Capresso Impressa S90 Espresso...
I have a Jura Impressa which is about 7 years old. I brought it in England. It is still working but i think it could do with a full maint check out. Where is the Jura agent in Bangkok who can carry out...
Please contact the head office in South East Asia for information about servicepartners in the region:
JURA SEA (PTE.) LTD
25 International Business Park
German Center #01-07/10
Singapore 609916
Tel.: +65 6562 8845
Fax: +65 6562 8854
Opening hours: Monday to Friday 09:00 to 17:30
http://www.sea.jura.com
Aug 03, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Open tap - filling system - close tap
Try using warm water in the watertank, important that the water is not too hot, it can cause leakage in the o-rings in the fluidsytem.
Repeat the procedure a few times, if nothing helps, turn off the machine and wait 1 hour and try again.
If you can`t get around this message, then the flowmeter needs to be changed.
Jul 10, 2009 | Jura Capresso Impressa E75 Espresso &...
Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
I am using the Jura Impressa E 80 Cappaccino machine. It is a and 1/2 years old. After machine stopped working and after a regular maintenance scedule I cleaned and descaled my machine (even though there...
Pill clean your machine.
Take out the filter for this experiment
Try adjusting your grinder to the full course setting. You will have to make three or four cups before you see the results of the new setting.
If the flow comes back to normal and the light problem goes away the problem was your grinder was set too fine. Replace the filter and try a few more shots. If all the water leaked out of the filter the lights will come on one time until the filter is purged of air and you should be good to go.
If you still have the lights coming on you have some type of internal restriction a technician will have to clear it . We repair Jura Capresso.
Jul 06, 2008 | Jura Capresso C1000 Espresso & Coffee...
Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
1,356 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
