Aa I type, my computer stops what I am doing (just happened there again) and jumps to the home page for internet explorer.
You have a virus which is trying to reach its website.
You need to run anti-virus software to get rid of it.
Try this
SUPERAntiSpyware Remove Malware Remove Spyware AntiMalware AntiSpyware...
SOURCE: How can I stop my curser from jumping around whilst typing ?
Hello
Most probably because your 'Touch Pad Mouse' is touched by your palm (hand or something) while you are typing. Avoid contact with the mouse touch pad while typing.
Option 2:
If you have a centre moveable mouse on your laptop, start using it and disable the 'Touch pad mouse'
Best of luck!
SOURCE: the cursor moves by itself during typing.
I have found this is usually the small button in the middle of the keyboard (mouse button) I have tried some software to remove this problem but it did not on my laptop I ended up carefully removing the key board and disconnecting the two wires that go to the button My cursors kept moving across the screen
SOURCE: when I'm typing, the cursor moves
I think thats the best answer I have heard so far the control F9..it actually worked..Thank you very much!
This is the first msg I have typed since I have had the computer where the cursor hasnt jumped..
I tell ya these forums are the best
Thanks again
MIkey J
SOURCE: When typing cursor keeps jumping
Generally there is a setting (CONTROL PANEL, MOUSE, Touchpad Tab) to either enable a feature like PALMCHECK or to disable the touchpad while typing. If neither option is shown, then try updating your touchpad driver
SOURCE: jumping cursor of a
Hi! I think youre probably having a jumping cursor where the cursor jumps from one place to another while typing an email or something. You may got to control panel - hardware - mouse then look for the check box that you can tick on that says "Tap off while typing" and this should fix the problem. Thanks for visiting FixYa.com!
