Question about Toro Lawn Mower With Toro Power Tools
Blade not engaging
Mower runs and is a self-paced toro mower,andwhen I push on the handle to walk it goes,butthe blade is not cutting anything.
  • Jeffrey  Orrell
    Jeffrey Orrell May 11, 2010
    is the blade tight,and are the levers fully engaged, one for go,and "run", the other for cutting depending on mower
  • 11,896 Answers
The blade will spin automatically when the motor runs because it is connected to the main shaft. If it is not cutting, it will have to be removed and sharpened with a grinding wheel
Posted on Jul 03, 2009
Where does the blade spacer go on a toro personal pace push mower
it goes: bolt, washer, blade accelerator, blade adapter in that order.
May 25, 2016 | Toro Garden
Toro 20333 self propel. Doesn't engage. l
Is the tension spring gone? How is the cable? Usually there is a spring at the end of the cable in which when you pull back on the bar with your hands, this tightens the belt so that it engages with the engine allowing the wheels to turn.
Oct 06, 2015 | Toro 20332 22" Personal Pace Walk Lawn...
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
Oct 02, 2012 | Toro 22 in. Personal Pace with Blade Stop...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
My toro walk behind self propelled blade disengages how do I adjust it
No adjustment, ensure no obstruction on drive end of cable, replace cable, probably stretched over time.
Jun 17, 2012 | Toro Power Lawn Mower
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
My toro self propelled lawn mower won't roll backwards... the wheels are locked up
My Toro Pace Master self propelled 22" 6.75 mower will not move by itself. I can push the mower and cut. It does start with no problem. I have a cable on left side of the mower that extends to the top of the handle broken off at the top of the mower and is loose. Is there a way to check to see if this is why it will not self propel. It attaches to the push handle that does I push down to propel the mower. Any suggestions?
May 07, 2010 | Toro Lawn Mower With Toro Power Tools
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
412 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
