Question about Karcher K2.26 Electric Power Washer
Runs constantly and leaks water from the housing
Used very little before this happened. Was using it up on the roof when it tipped over and began leaking and running constantly.
  • 174 Answers
There is an internal leakage or breakage. This will cause a leak and also cause it to keep running.
Posted on Jul 03, 2009
Black water coming out of returns from solar panels on roof of my home. Panels are 15 years old and there was frost in San Diego the nite before it happened
How do solar hot water panels work? - Explain that Stuff
www.explainthatstuff.com/solar-hot-water-systems.html
Jun 2, 2015 - Photo of solar hot water panels on house roof. ... What if you cut the top and bottom off a plastic bottle and fitted pipes at each ... This is the technical name for the big black panel that sits on your roof. ... The heat is then passed into the hotwater tank, and the cooled water (or fluid) returns to the collector to ...
Solar water leak - YouTube? 1:46https://www.youtube.com/watch?v=WaWkzfs6bikMay 22, 2012 - Uploaded by EnovativeGroupLeaky solar system, enovative group investigates... ... Solar water leak ... Solar Water Heating Panel and ...Pool Solar Panel - A How to Fix - YouTube? 2:50https://www.youtube.com/watch?v=f_KzEsxQhbEJul 7, 2012 - Uploaded by Clive WoodrowEasy and cheap way to fix a leak in your pool solar panel. ... The pipe (to carry the water to and from the ...
Dec 21, 2015 | Solar Pool & Spa
Can the water filter housing be the cause of slow water when the filter is in place?
Even a new filter will reduce the flow some what. I think the pressure to the filter is low or restricted . that will cause a reduction in flow, no it should not leak, check on the seal.
May 27, 2015 | Whirlpool Refrigerators
I have coleman air conditioning units on my 1991 Georgie Boy. They both leak... water from rain and also when units are shut off, lots of water comes back in. I bought gaskets but it looks like someone...
I'm thinking that motorhome has a rubber roof, so you don't want to cut at roof, or you'll likely end up cutting rubber roof which is certainly not a good idea. It may take some work but try prying and scraping with a plastic scraper while someone lifts up ******* upper unit. Quite often whatever sealant they've used to seal between roof and gasket will start to let go with constant upward pressure.(lifting) If you have fiberglass type roof and not rubber, scrape and pry where gasket meets roof.
Oct 05, 2011 | Dometic Rooftop RV Air Conditioner
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
When i run my rooftop unit, water runs down the outside of the roof jack and some leaks into the house
Could be that the float is not set properly to where the water shuts off when filled. Make sure that you adjust the float so that water doesn't spill outside the pan when the unit is turned off. But that enough water is available so that your pump has enough water to feed the pads. If you run the pump dry, you may overheat and ruin it.
Also, make sure the ducts are properly sealed so water doesn't leak into the house.
May 09, 2010 | Mastercool 67680 Evaporative Cooler Air...
The water refill tube on my icemaker freezes constantly all of a sudden. The water pressure seems low also, I used a self-tapping valve could this be a culprit? I have a Frigidaire model # 26BRSDB1. Thanks...
Most times the reason for the freezing fill tube is a leaking water control valve for the ice maker side. Unplug the electrical plug to that side on rear of refrigerator. If water continues to flow to ice maker the valve is leaking or damaged to the point that closing is not enough. If suddenly began I would not be concerned about a tap valve. Thanks, Sea Breeze
Mar 24, 2010 | Frigidaire FRS26R4A Side by Side...
Sunglo panels on roof leaking with hole how do i patch them
stuff with foam that grows then use roof sealant or RV roof self leveling sealant
Nov 20, 2017 | Sunglo Black Portable Liquid Propane Gas...
Leaking water
If it was moved with a dolley the dolley may have broken the water pump under the washer.
Mar 14, 2009 | Maytag Atlantis MAV8000
Karcher K2.26 Electric Power Washer Logo
275 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
