Question about Lexmark P6250 All-In-One InkJet Photo Printer
Lexmark X3480 I replaced my ink cartridge when the old one ran out of ink, but the printer has not accepted the new cartridge. It tells me that ''ink is low'', and prints everything in green. What do I do?
  • 46 Answers
There are 2 possible problems, or the cartridge is a refilled one or some problem by the cartridge itself. Try to change the cartridge.
Posted on Nov 10, 2007
Lexmark x3480 catridge incorrect
It could be faulty cartridge issue. Try to replace a new genuine cartridge to determine if the other is faulty.
Mar 16, 2012 | Lexmark X3480 All-In-One Printer
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
New cartridge fitted still reads low ink.lexmark x3480
Try this... Unplug the printer from power and restore power... also, reboot the computer. if that doesn't work, try reinstalling the cartridge or reinstalling the software. If there is an option to ignore these messages, it will be in the options srction of your printer manager program.
Dec 29, 2009 | Lexmark X3480 All-In-One Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
How do I change the ink cartridge on lexmark x3480
Please use lexmark solution center... here it is:
To install a cartridge using the Solution Center:
  1. Make sure the printer is switched on, the old cartridges are still in the printer, and the cartridge cover is closed.
  2. Click on Start, Programs (XP: All Programs), Lexmark <Printer Name>, Lexmark <Printer Name> Solution Center.
  3. When the Solution Center screen appears, click on the Maintenance button on the left-hand side. (This button is the third from the top and bears a picture of ink drops.)
  4. When you see the Install or obtain a New Cartridge option, click on it once. A pop-up displays a brief description of how to physically remove an old cartridge and install a new one.
  5. Follow these instructions and click Next. The software will prompt you to confirm whether the cartridges are new or old.
  6. For the new cartridge you just inserted, select No, it's new. Important: Make sure the setting for any old cartridge stays on Yes, It is old.
  7. Once your selections have been made, click OK. The program will want to run the alignment for any new cartridges you installed. This applies whether you changed one or both cartridges (in the case of printers that can hold two cartridges). An alignment screen with a red and white bull's eye will appear.
  8. Make sure the cartridge cover is closed and that there is paper in the printer.
  9. Then click the Print button on the alignment screen. A sheet of paper will print from your printer with a series of arrows and numbers on it, with one set of solid bars above them. You should see four groups of lines, unless you have a single cartridge. If you have a single cartridge, you will only have one set of lines.
  10. In each group, locate the arrow that looks the most solid. It may help to circle the number under each arrow you choose as you go along.
  11. On your screen, you will see an area where you can enter the alignment values. When you have identified all the numbers, select those same numbers for each group on your screen, using the up and down arrows next to each value for A, B, C, and D (or A if you have only one cartridge).
  12. When all the numbers have been changed to reflect the chosen numbers on the printed alignment page, click OK. The cartridge installation procedure is complete.
  13. You can now exit from the Solution Center.
Thank you......
Jan 15, 2009 | Lexmark X3480 All-In-One Printer
Lexmark X2530 won't accept re-inking of cartridges
This is a trick that is used on some of the HP printers. Try this, you will need at least 3 maybe 4 cartridges. The printer stores the chip ID in memory for the last 2 or 3 cartridges installed, so, take an old cartridge number 1 and install in the printer, reset power. Next step, take old cartridge 1 out and install old cartridge 2 in, let it come to ready or tell you to replace empty, then install your refilled cartridge. You just have to remove from its memory the chip ID of the refilled cartridge. You can fool it by doing this each time you refill. Can't guarantee this will work with lexmark, but it does work with HP.
Hope this helps,
Printdoctor
Dec 20, 2008 | Lexmark X8350 All-In-One InkJet Printer
Refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Aug 10, 2008 | Lexmark X2550 All-In-One Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
Lexmark P6250 All-In-One InkJet Photo Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
