Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Choke stuck After adding gas, tried to restart (Series 2000 CC Lawn tractor) but choke will not pull out, and tractor will not start. Lubrication did not help. Hope you can help!
    President:
  • 1,865 Answers
You may have to replace the choke cable assembly. Sometimes they rust to outer sleeve
Posted on Jul 03, 2009
How would I adjust the choke on my Briggs & Stratton 675 Series? where could I find the repair manual to download free online
Their's a bowl under the carb.,probably dirty,to clean,crimp gas line,get wrench and remove screw at bottom of bowl,discard gas and wipe bowl out and put back on and tigthen screw then uncrimp gas line and start.Be careful and don't damage rubber gasket.
Sep 21, 2015 | Briggs & Stratton Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
Kohler 16.0 HP Lawn Tractor, gas leaking from muffler when starting on choke. Also stalls when gas tank is 1/2 full.
It sounds like either a stuck float in the carb or a worn float needle and seat.
May 20, 2012 | Garden
My lawn mower starts up but seems like it has no power to rotate the blade. Added oil, replaced air filter and the spark plug but still has no output power.
Is the choke stuck on? That could do it. Does it rev high enough ? May need adjusting. You say you added oil was it low enough you have almost seized the engine. Just a thought
Sep 21, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I charged the battery and there's gas in my lawn
Usually there is a combination choke on the throttle, when you put the throttle all the way up it sets the choke and once the engine fires you idle it downa little to full throttle.
Apr 09, 2010 | Garden
Toro lawn mower wont start
pour alittle gas in carburator & then try starting see what happen if it starts & then dies then you have a carburator problem
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn mower died while mowing and won't restart
check the carb and air filter... also make sure its not gas from last season and make sure the oil is good.
Aug 16, 2009 | Garden
BMX Four Wheeler is sluggish, like it isn't getting gas
check to see if your needle is stuck or seat has become dirty, possibly try changin your spark plug
Aug 01, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Fuel flow on a Cub Cadet 2165 Tractor
Jim. It is probably the jet is clogged or the float might be stuck.Pull the bowl off of it and inspect.
Or try carb cleaner from the auto parts store
Kurt
Mar 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
497 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
