Question about Whirlpool ES5FHAXS Side by Side Refrigerator
Ice machine mod.#QD0452A dump valve staying on
I am reading voltage on the dump valve all the time can u help?
  • lfrink Oct 24, 2009
    The ice maker will not push ice out . The machine sounds like it is stuck. have cleared the opening and the machine will dispense about one glass of ice then does the same thing.
  • Mike Smith
    Mike Smith May 11, 2010
    I am sorry , but the problem you refer to , did not pass the required information into your request such as brand and correct complete model number . If you would care to elaborate and reply with that information , to this post , then Fixya experts will endeavor to help you further.
    Problem Solver:
  • 5 Answers
I am assuming that water is running all the time if it is turned on from the house water supply.
If this is the case try unplugging the flat or round cable that runs between the ice maker and the wall of the freezer. If that stops the power to the dump valve then the problem is in the ice maker itself.
You will have to remove it and check the switch contacts to see if they are stuck or broken. There is a thermal switch that causes the cubes to dump and then add more water to the trays. If you can't figure out how this system works but un-plugging the cable stops the power at the valve, the only solution is a new ice maker unit.
A new icemaker will run about $90 retail if you can't get the contacts working corrrectly.
If water is not running all the time it is likely that the ice maker is calling for more water and the valve is not responding. Get a new valve.
dwilli10
Posted on Nov 29, 2009
The icemaker won't make ice. If we put ice in the compartment it will stay frozen.
Is the ice maker getting water? Are there frozen cubes in the mold but they're not being dumped? If yes to latter question, replace ice maker. If no water is getting to ice maker, you will have to determine if IM is sending voltage to valve. If it is, replace valve. If it's not, replace IM.
Sep 19, 2017 | Refrigerators
Scotsman ice machine
Check the dump valve if water is seeping through the dump valve then the water inlet valve will be adding water to sump all the time to replace water lost. Now if water is running over sump into ice bin then look at water inlet valve.
Jul 17, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Machine keeps icing up and switching off
When you say ices up do you mean the line ices up back to the compressor. is water overflowing over sump tray? or is it dumping out drain? If you are not getting water over the evaporator plate then it will frost up the evaporator plat all the way back to the compressor.if the water is dumping into the drain during freeze cycle check the dump valve this will not let sump tray stay full of water. make sure water filter is good as this will not let sump tray stay full fast enough. is water pump pumping water over the evap plate?
Jan 03, 2014 | Kitchen Appliances - Others
This is a QD0452A ice maker it will not cycle properly, water will not shut off, have to watch cycle and manually shut off water ,let ice dump, then turn water back on.
It can be a variety of problems. The door bin switch should turn off the unit when it senses that the door is open (bin full of ice). It is a curtain that opens out to release the ice.
Next it could be the water inlet solenoid, it energizes to allow water in for the ice making process. If it stays constantly on then that would be your problem.
Look at the control board light indicators and you'll know what cycle it is on. These parts are energized and seek help if needed.
Sep 16, 2013 | Manitowoc SY0454A S Series Ice Maker...
Does dump valve shut off after making ice
is your bin line and dump line tied together if so it could be just ice melting. If not can you here water filling up constantly while machine is off? if so is it running over sump tray into ice bin. if dump valve was stuck open then machine will not make ice.
Jun 25, 2013 | Scotsman Kitchen Appliances - Others
Dump valve running continious its not turning off automatic
It's probably just stuck open and needs to be replaced. To order one you need model, serial, and voltage.
Apr 07, 2013 | Manitowoc QD0452A Ice Machine
Not making enough ice
What is the ambient air temperature in the location it is installed??
Aug 27, 2012 | Ice-O-Matic Ice o matic Iceu220a Cube Ice...
THE WATER NO STOP IN ICEMAKER MOD GSS25SGM GE
Improve the FixYa experience for everyone by voting.
Suggested approach to fixing your problem:
Your ice maker is designed to fill with water for 6 to 8 seconds. Depending on your city water pressure, anything longer than eight seconds will overfill the ice tray and either over flow the ice maker or create cubes that have difficulty ejecting.
There are two basic issues that commonly cause an overfill condition.
  • The first is an ice maker that is sending power to the water inlet valve for a period longer than eight seconds.
  • The next problem which is the subject of this answer is a water inlet valve that is closing too slowly. The power to the valve is being shut off in the correct amount of time, but due to imperfections in the valve, it is closing in a delayed fashion.
How to Diagnosis:
The easiest way to determine if your water inlet valve is the culprit, is to install a meter volt meter across the leads of the water inlet valve.
  1. Set the voltage range for 110v.
  2. Manually cycle the ice maker and watch the meter.
  3. When the ice maker begins to fill with water the meter will read voltage coming from the ice maker.
  4. Note the difference in time between when the voltage is cut from the valve and when the water quits filling the ice maker.
  5. If the water shuts off immediately when the voltage is removed, the valve is likely operating correctly.
  6. If this is the case, it is likely that the voltage will be applied to the valve for a period of time greater than eight seconds.
  7. This generally indicates an ice maker control problem.
However, if the voltage is removed from the valve and it continues to fill, the valve is likely at fault. This indicates that due to particle build-up or mechanical failure the valve has lost its ability to shut immediately. In that case, simply replace the valve and it should fix your problem.
May 13, 2012 | GE Refrigerators
2 problems one water escaping to the drain freeze cycle short
first, freeze cycle too short because you are loosing water. Water may be leaking thru the dump valve. Look at drain while machine is running and see of alot of water is draining. The dump valve spring may be week or there is trash in the dump valve preventing it from seating properly. drain water first before pulling dump valve apart.
Aug 29, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker not working
Pour about 2/3 cup of water into the ice maker . Also , check the black fill hose that fill the ice maker , to make sure it is not frozen . If the ice maker dumps the cubes , then replace the water inlet valve . If the ice maker holds the ice , and does not dump , replace the ice maker . When you open the freezer door , the laser light , should blink twice , then pause ,repeatedly . If you close the flap on the left side , the laser should go off . These are indication that the optics are good . If you open the door , and no laser light , then that means that the ice maker is in the harvest (dump) mode . If it stays this way , ice maker is bad .
Sep 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ES5FHAXS Side by Side Refrigerator Logo
267 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
