Question about LG WM2688HWM TROMM SteamWasher
Getting an E1 error code - LG WM2688HWM TROMM SteamWasher
  • 5 Answers
It should be the 1E error code. LG standard is xE indicating a code followed by E for error. Except in the cae of power failure which is indicated by PF.
E1 means inadequete water supply. This can be cause by a kinked hose in the back of the machine (going to the hot or cold water supply). A water valve (at your hookup connection) that is not fully open, or a clogged filter in the inlet hose.
Insure the valves are completely open on the wall behind the washer, and that the lines connecting to the washing machine are not kinked coiled tightly. If neither of these are the problem, shut off the water valves and disconnect the water lines from the machine and wall and insure that the screens in the hose are clear.
Good luck to you.
Posted on Aug 04, 2009
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    In the window then note comes up E1 ERROR . What is this. It does not sew.
    Consult the owner's manual. There is usually a list of error codes in the Troubleshooting section that discusses error codes and how to resolve them.
    Error Codes differ from brand to brand, so it is best to search for your machine's make, model plus "E1," ie:
    Frequently Asked Questions
    Why is my Kenmore sewing machine locked up with an E1 error code displayed...
    Simple Fix for Janome E1 Error
    Feb 14, 2016 | Sewing Machines
    Error code E1 and E4
    PDF]SERVICE Manual - Quietside
    https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
    When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
    Midea air conditioner error codes
    airmaster.net/midea-air-conditioner-error-codes/
    Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
    [PDF]Download the Fault Error Code Booklet - Samsung
    Dec 05, 2015 | Heating & Cooling
    E1 error code on omega dishwasher
    E1 error on LG Dishwasher - YouTube
    ? 2:40
    www.youtube.com/watch?v=2qcwAyHI9ik
    Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
    Aug 28, 2015 | Dishwashers
    Heating elements will not heat and getting an error code E1 F-5
    Hello,the lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed screw driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
    Thanks
    May 30, 2010 | Whirlpool Ovens
    I have a Tunturi j770 treadmill with error code E1. What does this mean please?
    Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
    May 17, 2010 | Exercise & Fitness
    I have laars heater model ht 330. there is no hot water and the heater displays error code E1
    E1 is only the first part of the error code. There should be one or 2 more digits being displayed, alternating with the "E1" display. Unless you provide the other 2 digits of the error code, I can't help you.
    You can get the user manual for your boiler/water heater with the error codes from here:
    http://www.blueridgecompany.com/documents/LaarsHT330.pdf
    Please, get back to me if you need any more help
    Alex
    Mar 21, 2010 | Heating & Cooling
    Kebc207 oven error code E1 F2
    This is information from the Tech Sheet.
    Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
    Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
    Washing Machines Logo
    458 people viewed this question
    Top LG Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
